Question about KitchenAid Architect? II U SERIES KUDS03ST Stainless Steel Built-in Dishwasher
My dishwasher's buttons will not work at all. Nothing is lighting up. I have already checked the breaker (not tripped, but I turned it off and then on again just to rule that out)... I assume that it is some control panel (the manufacturer said that it is a covered part... but I will have to pay the tech to come and install). Just trying to determine if it would be something that I can do myself and save some $. the unit is only 3.5 years old...
  • 1314 Answers
SOURCE: Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Posted on Jan 01, 2008
SOURCE: KUDIO1ILBS2 KitchenAid Dishwasher
KUDS01IL KITCHENAID DISHWASHER ALL CIRCUTS ARE ON BUT DISHWASHER IS DEAD. NO
RESPONSE WHEN TOUCHING CONTROL PANEL BUTTONS.
Posted on Sep 28, 2008
vitg55
  • 73 Answers
SOURCE: kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
Posted on Dec 08, 2008
  • 6 Answers
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Posted on Oct 17, 2009
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Posted on Dec 09, 2009
Kudi02cr Kitchen aid dishwasher not turning on. No lights nothing
check your breaker panel to see if the dishwasher breaker might be tripped. then be certain that the door is closing all the way and engaging the safety switch
Jul 04, 2014 | Dishwashers
Kenmore dishwasher wont turn on seems to have no power.
Check the breaker in your breaker box, it may have tripped. Reset it and run the dishwasher. If it trips again, have the dishwasher looked at by a professional service person.
Feb 13, 2012 | Kenmore Dishwashers
GE GLD4660N10SS dishwasher won't turn on
make sure your kithen ground fault detector has not poped closed. Push the red button to activate it.
Dec 30, 2011 | GE Computers & Internet
My Maytag dishwasher will not run. It is completely dead. Nothing lights up, etc. It is only a few years old.
Many newer dishwashers are wired to a switch on the wall as a means of service
disconnects in new homes. Also I would check the GFCI outlets in the kitchen area
and possibly the bathroom as well to see if they are tripped. (Press the test button and
then the reset button on them to test). The next thing I would check is the breaker
panel to see if the dishwasher is on it's own breaker. And lastly I would check the
connections to the dishwasher itself (after making absolutely sure power is off to the
wiring feeding the dishwasher at the breaker panel). I hope this is helpful.
Aug 06, 2011 | Maytag Dishwashers
My dishwasher was in the middle of a cycle and it just quit. The buttons dont light up. It doesn't turn on at all. What could be wrong with it?
Sonya, have you checked the circuit breaker in your home's circuit breaker panel to see it has been tripped? Also, is the dishwasher door tightly shut? If the breaker is tripped, reset it to see if the dishwasher trips it again. If it does, either breaker is faulty or the dishwasher has a short circuit in the electrical circuitry. You'll need an authorized service person for that.
Mar 21, 2011 | Heating & Cooling
MY DISHWASHER TRIPPED THE BREAKER AND WILL NOT COME BACK ON.
Hello- This series MDB7130 is involved in a recall. Check Maytag website for details. If affected, they will offer 75$ toward a new maytag.... or a free service call to 'retrofit' a new wiring harness. These units have caused a number of  fires so disconnect power until issue is resolved.- Let me know if this info helps. Thanks- Ed
Mar 12, 2010 | Maytag MDB7130 Dishwasher
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Just won't work!!
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
I would also advise to check the door switch as well. make sure the wires are connected to the switch and it is working. replace if found to be faulty.
Check the control as well. if the control is malfunctioning as you stated, this will be the logical solution here. replace the control board.
May 29, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
No power to dishwasher
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Nov 28, 2008 | Dishwashers
Kitchenaid 24" SS dishwasher
the first thing to check is power. check your breakers to see if any are tripped. if so turn it off than on some breakers do not reset if you just switch them to the on position. also check if it has a plug or shut off switch in a cabinet nearby .
Dec 31, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Open Questions:
KitchenAid Architect? II U SERIES KUDS03ST Stainless Steel Built-in Dishwasher Logo
32 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
