Question about Miele G848I Dishwasher
Washer won't start
Model G848 SCI
Dishwasher won't run when the "start" button is pressed regardless of cycle chosen. Machine behaves as if it's unplugged. Checked plug and power source and machine is receiving electricity. Checked for obstructions as well a making sure door is securely latched. Based on symptoms, it appears the "start" button is malfunctioning or defunct--- it doesn't seem to provide the resistance is usually has.
Am original owner and this s the first "breakdown" I can recall. Any idea what the problem is? Thanks!
Called Miele customer service and local authorized Miele repair & pretty much determined control panel has conked out. Replacement part is $500 + @ $100+ more for service call/repair. OUCH! Washer is 7 yrs old and this is the first breakdown. Looks fatal...
Posted on Jul 11, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How to fix my washer machine ,never stops running,after finish washing,starts with the cycles again by it self
The first thing you might try (if not already done) is to unplug the washer and let it sit for a minute or two. Then plug it in and try again. Maybe a good reset of the logic board will do something.
Does this happen regardless of the cycle chosen? What if you choose spin only? Do the cycle status lights work correctly? At the end of the cycle, before it starts again, does the "cycle complete" light come on?
This problem is likely to be a faulty logic board. Sears may be able to supply one. Perhaps your unit is under warranty.
Nov 29, 2014 | Kenmore Washing Machines
Washer won't start - sometimes
Jason, take a look at this link and follow the steps very carefully. Were insulated golves. How to Fix an LG Front load washer machine that wont spin
Feb 28, 2014 | Frigidaire Washing Machines
The clean button blinks. the only button that works is the drain button.
Hello
Confirm that the door is closed and latched. dishwashers can detect if the door is open and will cancel any cleaning cycles to prevent water spillage. Wait for around 20 minutes before unplugging or moving the dishwasher in case the washer is cooling down, draining or drying dishes. Call a technician if the dryer does not restart.
Verify that a cycle has been selected using the "Cycles" button and that the "Start/Resume" button has been pressed. Unlike some models of dishwasher, appliances won't start until you select a cleaning cycle and press the "Start/Resume" button.
Confirm that the dishwasher's electrical outlet is switched on, if necessary, and that power is being supplied by plugging in a lamp. You may need to replace a fuse or reset a breaker on the electrical circuit if the lamp will not work in the outlet. Ensure that the dishwasher is plugged into the outlet.
Ensure that the water shutoff valves at the wall are open and that the supply hoses are free of kinks. Your washer will not start if it is unable to access the water supply. Most shutoff valves need to be turned clockwise or moved to the "Open" position to work properly.
Open the door and check the overfill float in the bottom of the dishwasher. Push it down to make sure it can move up and down freely. The machine will not start if the sensor is stuck at the top. The overfill float looks like a small cone on top of a disc with a paddle attached to the side.
Sep 12, 2011 | Whirlpool DU1055XTV 24 in Builtin...
It will not start. The buttons at the top usually turn green to the touch and then it automatically starts. If I didn't know better I would swear it wasn't plugged in. I already checked the fuse...
Hello
There are several situations that could cause a dishwasher to fail to run. You can troubleshoot your way through the most common of these situations using manufacturer-approved troubleshooting steps. This troubleshooting approach prevents unnecessary repair visits, saving you money. dishwashers will not run without power, water or correct setup. Troubleshooting your dishwasher will take about 10 minutes. The exact location of buttons and parts will vary depending on your model of dishwasher.
Sep 12, 2011 | Whirlpool Dishwashers
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Miele G848I Dishwasher Logo
258 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
