Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Water leaking from the the water feed contector
    Problem Solver:
  • 8 Answers
Tighten the nut holding the connector in place. Do this carefully, too much force can damage the seal.
Posted on Jan 03, 2011
Leaking washer
What leaks exactly?
What should we be guessing at ?
You changed one of the two hoses that feed
water to the washer?
Then turned off the water at the watts valve or
the hot or cold water--why?
No you have no leak until you turn the water back on?
Nov 27, 2014 | Samsung WF448AAP Front Load Washer
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
All contector chartring and without load
In there is charring of the wires without the heater turned on and heating and it's a 240 volt system, there's something seriously wrong with wiring in the heater. Turn Off the circuit breaker in your home's breaker panel that feeds this heater and call an electrician. This is not a DIY repair. At best, it would be a very risky DIY repair.
Mar 08, 2011 | Fahrenheat Electric Hydronic Baseboard...
Hoover Dishwasher HD95M leaks on start up from bottom right front corner. Leaks when initially being fed from water feed.
Water leaking can be poor plumbing or fault in the inlet hose connection. You are the first observer and so your view on the leak area is important as the leak can be from the hose, from the inlet, the hose or the washer unit.
Based on this the water leak can be plugged, tighten the hose clips, check the inlet filter or check the washer's feed line.
Feb 09, 2011 | Hoover HD95M Free-standing Dishwasher
I have a GE model TPX 24BPBA WW and have a water leak on my floor. I disconnected the icemaker water feed and leak stopped. What's wrong
do you live in an area where there are rodents such as mice ? if yes there is a possibility that they have eaten the plastic water line that feeds from the ice maker water valve to the ice maker itself . when they get thirsty you would be surprised what they will actually chew through to get water. regardless the cause, you probably have a broken water line between the ice maker water valve and ice maker unit .
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hydronic heat water feed valve
You should be ok. Most of the time the boiler are charged to about 10psi and dont have feed valve. You would only feed if you have a slight leak in system. Rus
Dec 05, 2009 | Heating & Cooling
Freezer don't get cold-fan turns on ,timer is ticking,black thing under is vibrating,coils are clean
1st check the compressor working or not working .OK compressor is working system gas leak ,not working check the capacitor and timer contector
Jun 20, 2009 | Frigidaire Freezer FFU11FC2CW 11.2 Cu.Ft....
How to remove negative battery terminal
dont remove it if your radio has a thing called theftlock or youll have to take the car to a certified GM dealer to get the radio unlocked but you can still clean it with a cup of baking soda and warm water mixed and scrub it with an old toothbrush
Apr 26, 2009 | 2006 Pontiac G6
Brand new battery installed, still no power?
YOU COULD HAVE A VERY BAD CONTECTION FROM BATTERY TO STARTER, TRY TO ATTACH LEAD DIRECT TO STARTER (LARGE FEED CONTECTOR) FROM JUMP BATTERY AND THEN CRANK WITH FULL BATTERY, IF SAME STARTER IS JAMMED OR SIEZING UP
Feb 02, 2009 | 1985 Chevrolet S-10 Blazer
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
47 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
