Question about Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera
Can't format memory card on maxxum 5D
My Maxxum 5D does not recognize the memory card. Will not see the card or format it. have tried several brands of compact flash cards.
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Memory card will not go in all the way and the door won't shut.
    was it working before?
    turn the memory card anyway and have a try - before check inside the memory card compartment with a flashlight if you can see the contacts at the bottom and insert the card corresponding to them.
    Or try another card to exclude yours is not damaged or wrong type somehow....
    Konica Minolta MAXXUM 5D Instruction Manual Inserting And Changing Memory...
    Mar 07, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
    Old pictures show up fine but new pictures show up very darkkk
    two reasons for this are possible:
    1) you changed the exposure compensation by mistake to minus something... - see below - change it again to +- zero:
    Konica Minolta MAXXUM 5D Instruction Manual Exposure Compensation
    2) you should have the ISO settings to auto:
    Konica Minolta MAXXUM 5D Instruction Manual Camera Sensitivity iso And...
    Jan 28, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
    Trouble installing the memory card.
    Is this the original memory card? if not! and you recently bought one card, sounds like the right configuration but it is a bit to long for the camera body. I suggest taking it to a camera shop to make sure it is the right card.
    Mar 30, 2012 | Konica Minolta Dynax 5D / Maxxum 5D Body...
    I can't find the driver(s) for a Konica Minolta Maxxum 5D Canera. I found one for Windows 95/98 but it will not work with the Vista 32 bit Home Premium Operating System.
    You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( ).
    Mar 14, 2011 | Konica Minolta Dynax 5D / Maxxum 5D...
    Need to set self timer
    Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). To start the self-timer, press the shutter release button.
    Sep 06, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
    The memory card release want reset after removing the card. It stays out and wantlock back into place on my Maxxum 5D Camera.
    did some one put the card in wrong..?? there is a small plastic pin that grabs the memory card and holds it in place... if its broke its tear the camera apart and ouch
    Jul 17, 2009 | Cameras
    Looking for Digital Camera to use lens
    Your Minolta QTsi Maxxum takes a Konika Minolta AF lens. These lenses work on these Konika Minolta DSLR cameras:
    DYNAX 5D / Maxxum 5D
    DYNAX 7D / Maxxum 7D
    Dec 16, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
    Bracketing in Maxxum 5D
    Hey arnelsartwor,
    To set both exposure and flash bracketing you need to press the drive mode button, and then use the up/down arrows to select bracketing and then use the right/left arrows to highlight the drive mode option and then press the center button to select the desired drive mode. These instructions are on page 50 of your user manual. I hope this helps!
    Go Ahead. Use Us.
    May 23, 2008 | Konica Minolta Dynax 5D / Maxxum 5D...
    Minolta Maxxum 5D
    The P-channel MOSFET switching the CF power is dead. It is on the little board directly above the battery compartment. SOT23 package, the marking is 338 or something like that. Replace it and it will work.
    Mar 04, 2008 | Konica Minolta Dynax 5D / Maxxum 5D...
    Camera freezes after taking picture
    Shooting in the dark here, but the basic things you should try before all else is another mem card, and new compatible batteries. sounds more like a card problem though. hope it works out
    May 12, 2006 | Konica Minolta Dynax 5D / Maxxum 5D...
    Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera Logo
    134 people viewed this question
    Top Konica Minolta Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
