Question about Canon PC150 Personal Copier (PC 150, PC-150) Printer
CANON COPIER PC150 IS MAKING NOISES THAT SOUND LIKE A JACK HAMMERE AS IT COPIES AND THEN GETS JAMMED. ANY SUGGESTIONS FOR WHAT MIGHT BE GOING WRONG??
  • 591 Answers
Sounds like a worn fuser drive gear you need to replace the gear by a good tech. (NOT A DIY JOB)
Posted on Jan 03, 2011
Indentations & wet ink when copies come out of machine
Fusing assy. is bad - must be replaced by tech.
Mar 02, 2010 | Canon ImageClass D660 Copier
After making a lot of copies- Dialta 3010 copier jams every time
you probably need you fuser rebuilt. the heat roller melts the toner into the papew. it is covered in teflon. over time the teflon wears off anf toner sticks to it causing paper jams when the copier gets hot
Dec 30, 2009 | Konica Minolta DiALTA CF910 Copier
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Copier make squeky sound while making copies...
Whatever you do, DO NOT PUT OIL ANYWHERE ON THE COPIER!!!
The rollers are wearing out; you will have to call Canon to send a tech, or, if you are a qualified Canon Tech or have one in your office, have them look at it and order the necessary parts.
Oct 07, 2009 | Canon imageCLASS D320 Digital Copier
Paper jammed as it was coming out
First, I prayed for help since I was using the copier when it jammed and then I very carefully pulled a small bit of paper on one side being certain not to tear it, then the other side. After about 30 minutes by using a eyeglass screw driver to help the paper come out, it pulled out and looked like an accordion. I put the toner back in and it worked fine. After reading the reviews, we won't be making double sided copies on this machine.
Thanks for your assistance.
Apr 12, 2009 | Canon PC-1080F Plain Paper Laser Fax
Darker copies
GO ON LINE AND TYPE THE FOLLOWING INFORMATION.
CANON PC-150 GRAYSCALE COPIER SERVICE MANUAL AND DRIVERS
OR
CANON PC150 COPIER DRIVERS SERVICE GUIDE
CANONUSA.COM
IF A USERS GROUP FOR CANON FORUM
TRY TYPEING THE FOLLOWING:
CANON PRINTER USERS GROUP FORUM
ENTER
PICK FROM THE BEST OF WHAT YOU NEED IF ANYTHING.
ROD
Feb 09, 2009 | Canon PC-150 Grayscale Copier
Paper curling due to condensation
All copiers have thermal fuses that should blow if copier gets too hot,so there's probable nothing wrong with the machine but the paper.When paper gets damp it curls. This is because when the paper feeds through the fuser a combination of heat & pressure dry the paper out causing it to curl!
Jul 13, 2008 | Canon imageCLASS D320 Digital Copier
Problem with canon pc150
Change  drum or fuser.
Take out drum is there a black ring on the sides? change
take out fuser is it worn on the sides? change.
Oct 29, 2007 | Office Equipment & Supplies
Canon PC150 Personal Copier (PC 150, PC-150) Printer Logo
60 people viewed this question
old marine
old marine
