Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Replace drum message won't go out even though we have replaced the drum twice.
  • 488 Answers
1. Open the front cover and then press Clear.
2. Press 1 to reset.
Posted on Jan 03, 2011
Msg says Drum Unit Life Order K Toner but my K Toner is at 90%.
The drum may have an electronic counter installed and after so many pages being printed, even though it is still good, it will determine that it is time to replace. You may be able to replace the electronic counter. If not, you will need to replace the drum.
Jul 03, 2014 | Oki Brand Oki C530dn Laser Printer Duplex...
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
Orange exclamation point is blinking, screen says "replace supplies", but it says that all the time. Nothing will print or copy. It will scan the document like it's going to copy, but then just stops....
I'm a tech on that printer. That's a generic message if one cartridge is at 0%. When one toner or drum reach 0 it wont print even though you don't use that supply. The unit should show the level on the screen, if one is empty replace it.
Aug 04, 2010 | HP LaserJet 2840 Printer
I recently noticed a message that said "drum end soon" on the screen portion of my printer. With that I went and replaced the drum and toner. The problem is this: The "drum end soon" message never quit...
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
Jun 09, 2010 | Brother MFC 7840W Printer
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
MFC 9700 Drum replacement problem
In the box with new drum is manual how to reset this, however, will not show solution for this particular model. So you ned:
1. Open cover (as to replace drum or toner). On display you will get "Cover Open"
2. Press right arrow under LCD display.
3. Press 1 (digit one) on keypad.
4. Close the cover
Done.
Dec 29, 2008 | Brother MFC 9700 All-In-One Laser Printer
Error message
The code listing I ran across says that's a replace fuser.
How old is the printer. and how many pages have run through it?
Oct 28, 2008 | Lexmark C510 Laser Printer
Replace drum
1.Power off the printer.
2.Open the top cover.
3.Press and hold the gray oval button on the operator panel below the indicator lights
4.While continuing to hold down the button, power on the printer.
5.The lights on the front panel will flash twice, then release the button.
The drum counter should now be reset. End of procedure.
Nov 05, 2007 | OKI B4250 Led Printer
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
73 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
