Question about Whirlpool Duet GHW9150P Front Load Washer
When we shut the door the status lights to the left dont come on thus not allowing it to start
  • 43 Answers
If in 10 seconds of no signal to readiness signifies the faulty lock a door.
Posted on Jan 03, 2011
When the engine is running the door open indicator on the dash shows a door open, thus when the engine is off the dome light stays on, what could cause this?
On the doors, and in some vehicles the trunk, there is a pushrod style tab similar to a fridge door. When the door is closed, it pushes the tab in, and shuts off the light. Vice versa when one of the tabs is fully extended the light turns on. Check all your doors for the tabs and see if any of them are broken. If they are, then you can solve this by using something to push into the cavity and shutting off the light. Without replacing the broken parts, you could use a small wooden dowel rod in it's place for a temporary fix.
Alternatively, there should be a toggle switch on the dome light that allows you to choose whether the light is on, comes on when the doors are opened, or remain off. It would be just as simple to switch it to 'off' provided you don't rely on it too heavily.
Jan 30, 2016 | Ford Taurus Cars & Trucks
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
Dryer door does activate switch when closed.
The switch could be loose thus not allowing to properly engage.the door may be slightly warped . Try flexing it back. Check and see if the door meets the body when shutting it almost all the way. The distance should be equal at the top as is the bottom.
Jan 30, 2013 | LG DLG5988 Gas Dryer
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
Sep 22, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Interior lights wont turn off. Door switchs are not stuck. I can activate all my door switchs and hear the mane switch in the rear click on and off. Where is this other swich?
your car has door switches in the door with a specific resistance. if you cannot shut off the lights with the dimmer switch your rheostat in the light switch is a culprit. some luxury models dont allow you to shut off the dome from the light switch. i would check the internal door switches first. hard to find. just follow two wires inside the door next to the door mechanism.
The switches get dirty and show a resistance to shut off the interior light.
Apr 20, 2011 | 1993 Lincoln Continental
Which wire is connected to which spot on the door switch? help =(
The white is the common and the gray is for the light the yellow allows machine to start and run when the door is closed.. Just hook them up if the light is on with the door open it should be good to go... If the light is not on then switch the yellow and gray.
Apr 07, 2010 | Amana NDE7800AY Electric Dryer
Have wd62525 mitsu status light flashes tv wont
The status light flashing usually indicates the lamp cover door or the side air vent door are open or the switchs are not working.
Mar 16, 2010 | Televison & Video
Lights just blink on the dryer...same problem
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Sep 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Flashing status light
Wow I may have just fixed the flashy yellow status light problem. It's so siple yet so difficult. Looking at the front of your T.V. on the left hand side bottm there is a door for a filter. SMACK IT. if the door isn't shut all the way that status light will flash. Mine is turning on now, just have to work on the major problem now :) Hope you have the same simple problem.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Whirlpool Duet GHW9150P Front Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
