Question about Fisher and Paykel Washing Machines
Machine wont fill with hot or cold starts to fill for around 5 seconds then stops for couple of seconds then starts to fill again couple of seconds thisprocess repeats its self 6 or seven times then 3 or 4 lights stay on and gives a single beep every second have tried filling by hand it will pump out but wont wash or spin thank you troy happy new year.
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
You will need to replace the RPS sensor. Here is a link to the part.
Posted on Jan 03, 2011
How do we get the machine to start?
Hi,I dont know if this is eney help but I just bought a tassimo - coffee machine and it sounded just like you described yours,
I pluged it in,then I took the water container of the back where I found a yellow disc,(do not remove the bar code from the yellow disc other wise the machine wont work) I inserted the yellow disc where you put the t-pods,then fill water - container and put it back in place,then I switched the on switch on,it should show a yellowy orange light nexst to the silver button,then press and hold the button for 5 seconds and let go,the light will flash and turn green,then give it another 5 seconds then hold the silver button in again it should now despence hot water ,when water stops press the silver button again do this about 4 times,now your machine is ready to use,take the yellow disc out and put it back in the place you got it from,
now just put the t-disc you want to drink and have a rest.
I hope this was some help.
Feb 11, 2015 | Krups Coffee Makers & Espresso Machines
Washing machine stopping and starting when filling
Sounds like maybe a bad water inlet valve? timer may have isses as well? have u tried running it in hot water only and cold water only cycle? see if one line is bad in ur inlet valve?
Dec 16, 2014 | Washing Machines
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
We have a Westinghouse Laundromat 800 (7Kg)that overflows. It appears that the when it fills itself with water (hot or cold) it does not automatically close the valves(?). Can you please help. Thanks.
Hi just read your posting.Now try this.Select only cold water fill and start cycle,then when you hear water entering your machine turn the power off at the wall.The water should stop filling straight away.If it does try the same test on your hot water.If either of the valves are faulty it should continue to fill after you have turned the power off to the machine.Please reply and tell me if the hot or cold water did not stop or if they both stopped.Please try the test on hot and cold a couple of times to be sure.Looking forward to your reply.
Jun 27, 2010 | Washing Machines
Fisher and paykel GW709 fill valve problem
the rods have nothing to do with the water level switch. I say check ur water switch with a meter. you may have defective coils, also check the water pressure switch
Mar 21, 2017 | Fisher Washing Machines
Fisher and paykel smart drive top loader , Wont fill properly .
Well where to start .....
This brand has a hell of a lot of quirks.
The first thing to try is this : With the power on at the wall and the machine off ,push and hold down the start button , then push and hold down the power button you may hear up to 3 beeps at this time (hold down the buttons for 5 seconds then release) turn machine off and turn it back on and just push start button.
What this does is re programes the computer ,then just leave machine to run cycle
Jun 12, 2009 | Fisher and Paykel Washing Machines
Compressor runs for 5 sec then stops
If it starts & stops frequently and you don't have a hot or cold tube at the compressor, you need it recharged. Check around for service. It costs between $150-$200 in my area.
Feb 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
F&P Smart drive 9
I had the same problem.
You probably only have cold water connected and you need to "program" it for cold water only.
By default it expects both cold and hot water connected and even though you can select "cold" it will still error if not hot water supply is present.
Call Fisher & Paykel customer care and they will tell you how to re-code it for cold only.
Oct 05, 2007 | Fisher and Paykel (IWL12)
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
