Can't get into my control panel or any operation system that has to do with disc clean up or any mateince
    President:
  • 2,351 Answers
Hi donna9, have you tried windows system restore? Click the start button, slide to programs & slide up to Accessories than to System Tools. Click System restore. You will not loose you're personal data. Also check you're antivirus software. Make sure it is up to date & run a full system scan. If neither have helped you gain access to the programs in windows there is only one other recourse. (A full install of windows). It's impossible to repair the windows files connected to these programs.
Please back up you're personal data to a second drive (copy & past) or a CD/DVD because you'll need to format the drive. (All a pain in the rump).
If you have restore CD's you can run them.
To make sure this is not a drive issue if you have to do a fresh install of windows. Find the primary drive's name. Example: Seagate, Western digital, Samsung. Find the model number of the drive. You can find the model number of the hard disk drive by opening windows device manager. Right click once on My Computer. Slide to & left click on properties. Click the hardware tab & than click the device manager button. Click the + sign next to Disk drives. Listed there will be the model number of you're primary drive. Write it down. Example: ST3160827AS.
This is a Seagate drive. Go to the manufactures web site & download the setup tools/utilities. You'll be able to create a bootable floppy disk or if you choose to create a bootable CD. This software work's outside of windows & will check you're drive for errors & repair it if needed. Whether the software does or does not find an issue with the drive it is possible you will loose you're data. This is why I'm suggesting this rout before installing windows fresh.
Good luck donna9!
Mike
Posted on Jul 09, 2008
How to remove microsoft window cleaning tool
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
if you need more help with this post a reply
hope it helps
Apr 13, 2012 | Microsoft Windows XP Home for PC
I have a Compaq presario f700 model laptop computer that was working fine until last week now what happens is when I turn it on I get the hp logo on screen long time then it disapears and the screen...
Try to clean the Hard disc connector on your laptop motherboard or Sata controller if you are using sata hard disc. There is loose contact there try to clean it with a piece of paper.
Jul 19, 2011 | Compaq Computers & Internet
How do go about making my recovery disc?
First open control panel,
Next open the system and security menu
Then open the Backup and restore menu
On the left side there should be an option saying "create a system repair disc"
Follow the instructions that appear on screen
May 31, 2011 | Compaq Computers & Internet
I lost my audio device after re install window xp
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 27, 2011 | HP Computers & Internet
Clean hard drive back to factory settings
I am one of the technician who are trained and had experience with different computer manufacturer with A+ certification.
First check if your computer came with Operating system.
- for branded computer its called recovery disc
- for self build computer, prepare for the operating system.
If you do not have an operating system disc.
- for branded computer such as HP or Dell, contact the manufacturer and request for one, some manufacturer are selling the recovery disc, some are for free.
- for self build computer, you can purchase the operating system from computer store
For steps on installing the operating system with screen capture here is the link that can help you.
http://screenshots.modemhelp.net/
Operating system procedures can be found in the right panel.
Hope this helps a lot.
Thank you for using fixya
Feb 27, 2011 | Computers & Internet
No sound or driver
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 03, 2011 | Computers & Internet
My laptop process is very slow when it is started
There are many things you can do to speed up your laptop:
1. Try going to the control panel add/remove programs (or a variation thereof depending on your operating system) and removing programs that you dont use anymore.
2.If you have more than one hard drive (as in when you click my computer you have a C drive and possibly a D drive move any documents or large files over to the D drive.)
3.To speed up start up try clicking the start button and going to run, typing msconfig, and then clicking the startup tab. Uncheck anything that you know you dont need at startup i.e(microsoft office and things like that )
Here is an article with more steps for things you can do.
http://www.microsoft.com/atwork/maintenance/speed.aspx
Jun 04, 2010 | Acer Extensa 4620-6402 Notebook
Disc Detector
Go to Control Panel
System , Hardware , Device Manager , Disk Drives
Click on the plus sign.
Jun 25, 2009 | Microsoft Windows XP Home Edition
CD/DVD reads no disc after inserting working CD/DVD
More than likely it has dust on the laser eye, it will need to be cleaned
Feb 22, 2009 | Bose Lifestyle 48 System
Computers & Internet Logo
David Payne
David Payne
