Question about Briggs & Stratton Garden
Which is the exhaust valve and which is the intake valve? How do you tell which is which.
    President:
  • 1,082 Answers
The valve closest to where the exhaust manifold bolts on, is the exhaust valve.
and Vice - versa for the intake .
Plus the exhaust manifold port (hole in the cylinder head) is usually dark with soot, whereas the intake port is usually clean-ish.
Posted on Jan 03, 2011
What is wrong when the manifold valve isnt closing?
manifold valve. Intake or exhaust. i guess intake.
where are you exactly ,
the 2009 , which engine?
the intake on some engines have many valves.
intake runner.
main throttle is an air valve.
VSV valves , for EVAP system, that too is an intake valve.
why not post symptoms
and if you see a valve acting funny, send a photo or tell
exactly it connection, locations.
or login to alldata.com and just look.
Jun 06, 2014 | 2009 Jeep Compass
98 oldsmobile achieva front head push rod order
You are thinking too hard.
It is VERY simple. The Intake valve push rods (marked with ORANGE paint) are shorter than the exhaust valve push rods (marked with BLUE paint) If you cannot see the paint, you can always stand them up next to each other...it is pretty obvious which ones are which.
BOTH heads are EXACTLY the same - they are interchangeable. It is just that one is turned one way and the other is turned the other way so the exhaust and intake ports will be on the correct sides. (intake port towards the center of engine, exhaust port to the outboard sides of the engine.) You do not need to go searching the internet for some "order". All you have to do is LOOK AT THE HEAD to tell which valve is intake and which valve is exhaust.
So then it is as simple as: Put the short push rods on the intake and the long push rods on the exhaust....
Apr 21, 2012 | 1998 Oldsmobile Achieva
Which side of the motor on a 3.1 buick 1998 century is the intake side and the exhaust side. I'm installing push rod that are different lenghts and call for exact positioning on the intake side as well...
That is a V6 or V8 standard mounted engine. When they say intake side and exhaust side they are talking about the valves. Typically each cylinder has 2 valves the front valve is the intake the back valve is the exhaust.If you haven't already gotten it I highly recommend you get the Haynes or Chilton's repair manual from your vehicle so you have the adjustment specs or priming procedure if you have hydraulic lifters.
May 20, 2011 | 1998 Buick Century
I want to set valve clearances on 1997 2.6 petrol holden rodeo. i need valve sequence? how can i tell which is exhast and which is intake?
the valve clearance is intake .006 exhust .010 they must be set with engine cold passenger side is the intake driver side is the exhust send me your e-mail and i will send you the procedure.
Apr 08, 2011 | Isuzu Rodeo Cars & Trucks
Making sure i'm on the compression stroke
The compression stroke is when the piston is traveling UP and the intake and exhaust valves are both closed.
Intake: Piston going down, intake valve open, exhaust valve closed
Compression: Piston going up, intake and exhaust valves closed
Power: Piston going down, intake and exhaust valves closed
Exhaust: Piston going up., intake valve closed, exhaust valve open
Mar 16, 2011 | Toyota Tacoma Cars & Trucks
I have a 2010 MTD Yard machine 21 inch snow thrower {123cc} and it broke a valve tappet bolt.I need to no were to set the intake and egzaust valves clearance.Thanks!
I can give you Briggs and Stratton figures for valve clearances of an engine this size. You may have to experiment a little till it runs right. ...you can adjust the intake valve (when it is closed) while the exhaust is open and adjust the exhaust valve (when it is closed) while the intake is open if you can tell...or ya can adjust them when the piston is at TDC on compression stroke (both valves closed). Intake: .004"-.006" Exhaust .004"-.006" (Vertical crankshaft)....for horizontal crank .004"-.006" Intake.....Exhaust is .006"-.011" Hope this helps . Here is a briggs engine specs chart..can';t find the Chinese engine listed anywhere http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Jan 21, 2011 | Garden
How do you tell if you are on exhaust or intake stroke on a 1.6 geo prism engine
The intake valve will be opening or open on the intake stroke and the same for the exhaust. If you are looking for TDC for timing purposes both valves will be closed and as you keep turning the crank the exhaust valve will start to open. Just back it up a little until it closes and your timing marks on the crank line up. Hope this helps.
Jul 02, 2010 | 1991 Geo Prizm
Procedure of tappet adjustment
make sure engine is warmed up. Put cylinder one at top dead center,remove the valve cover,loosen all adjustment lock nuts,adust intake and exhaust valves on cyl #1 and intake valve on #2 and exhaust valve on #3. now rotate crankshaft 360 degrees clockwise, now adjust intake valves on cyl#3 and cyl #4 and exhaust valves on cyl #2 and cyl #4.now tighten lock nuts and install valve cover. specs are intake valves 25mm clearance and exhaust 28mm clearance, use a feeler gauge,heres a picture to show you where to check clearance.7675a52.gif
Mar 14, 2010 | 1986 Suzuki Samurai
How do i adjust the valves in a ford 1997tarus with a 3.0 ohv
Valve Stem to Guide Clearance · Intake
0.026-0.071 mm (0.001-0.0028 in) · Exhaust
0.038-0.083 mm (0.0015-0.0033 in) Valve Clearance
  1. With No. 1 piston (6108) on top dead center (TDC) at the end of compression stroke (Position No. 1 in the illustration), check the following valves:
    Position 1
    No. 1 exhaust valve (6505) No. 1 intake valve (6507).
    No. 3 exhaust valve No. 2 intake valve.
    No. 6 exhaust valve No. 4 intake valve.
  1. Rotate crankshaft (6303) 360 degrees to position No. 2 and check the following valves:
    Position 2
    No. 2 exhaust valve No. 3 intake valve.
    No. 4 exhaust valve No. 5 intake valve.
Oct 19, 2009 | 1997 Ford Taurus
Garden Logo
382 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
