Question about Nordic Track Exercise & Fitness
Rower r5 flywheel won't recoil - Nordic Track Exercise & Fitness
2 Suggested Answers
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required. http://www.briggsandstratton.com/maint_repair/
Posted on Jul 21, 2010
I have a Tecumseh vertical shaft (TVM195 1502630 (C) )electric start engine, would like to change it to recoil start, what parts do I need?
Will try to answer your question.First your shroud cover that cover flywheel. Does it have threaded holes to bolt recoil on it. If not you will need to find a donor engine the same size. On donor engine remove shroud then remove bolt holding flywheel there will be a washer and recoil cup remove both. Remove other shroud and safety screen then flywheel nut and install donor parts the same way and should be all you need to do. One thing... Check flywheel for locking hole or slot for recoil cup so it does slip when pull recoil cord. If there is no way to do this you will need to change flywheel too.But if there is no teeth for electric starter you will lose that option altogether for electric start if you want both.
May 11, 2016 | Tecumseh Garden
How to take the toro snowblower flywheel off?
You dont need to remove flywheel to repair recoil. Just remove housing an underneath is recoil wheel an all. Easy repair you can do it unless freeze is in motor
Dec 14, 2013 | Garden
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
My flywheel won't catch the pully for the handle starter, why?
Possibly broken started pawl on the inside of the recoil housing, better get your tools out, its not a tough job.
Sep 12, 2011 | Husqvarna 28cc Gas Line Trimmer
4hp briggs and stratton roto tiller motor will not engage when pulling the rope
There are 3 metal arms that come out when the recoil is pulled. These arms can get dirty or rust and stick in so the recoil won't engage the flywheel or crank. .You will need to pull off the recoil and lubricate and work back and forth the arms.
May 16, 2011 | Sport & Outdoor - Others
Troy tiller won't crank
is it electric start or manual pull?? remove pulg and see if it cranks over. Could be mouse nest under recoil cover or under flywheel, could be rusted to the magnets. need more info. Oh yea make sure belts are not holding you back remove them or make sure they are loose.
May 05, 2011 | Troy-Bilt Pony Garden Tiller
Cord is stuck. Can't pull it
is cord stuck out or in? sounds like possible fan/flywheel cam loose on you which will cause this, take recoil off and see if it rolls over by hand with spark plug out, if so then reinstall recoil and see if pull rope works then, if not check fan and/flywheel on opposite side you will have to dissasemble case to do this, lots of screws, once there check flywheel key in flywheel to see if it has spun, if so you will need new flywheel approx$ 60.00 part hope this helps you
Apr 13, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Reebok fusion rower rev 11401 - how do i get it to see my polar heart rate monitor watch
I had cause to strip the covers off my rower now i find the strap does not recoil as supposed what have i done wrong with the reassembly...please...thx.its a reebok edge/fusion.
Sep 23, 2009 | Reebok Exercise & Fitness
How do you remove the recoil starter cover. I
which kind of chainsaw, make, model, how old?
Jul 09, 2009 | Garden
Fluidrower strap does not recoil.
Probably is the one way bearing broken. You can order one at your agent.
Regards,
First Degree Fitness
Dec 29, 2008 | Neptune First Degree Fitness Fluid Rower...
Exercise & Fitness Logo
116 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
