Question about Eureka 2961AVZ Bagless Upright Vacuum
How to change the belt on a eureka lightspeed bagless
reddevil6
  • 1673 Answers
SOURCE: belt change for eureka capture
There 2 or 3 screw on the top cover to remove, then it comes off. Then you can get to the belt, inspect the brush roll while you have it out, make sure the ends move freely.
Posted on Jun 22, 2008
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
ukvacfan
  • 328 Answers
SOURCE: looking to replace vac belt on eureka altima bagless upright
Hi Jim You should find the cross head screws on top of the hood - look below the duster and there should be a screw there, also another screw on the other side and two either side of the main floor head.
Posted on Mar 06, 2009
  • 13 Answers
SOURCE: My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Posted on Jan 30, 2010
SOURCE: broken belt
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
Posted on Aug 18, 2010
Eureka lightspeed upright vacuum bagless 4700d manual
Hello, this is Ava with Think Crucial.
Please refer to the link below for the Dyson DC33 online manual:
https://www.manualowl.com/p/Eureka/LightSpeed-4700D/Manual/1842164
You can purchase a wide variety of high quality Eureka replacement parts for your Eureka Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=eureka
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 11, 2012 | Electrolux 4700D Light Bagless Upright...
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
How do I change the belt on Eureka 4704 and where do I get belts
you can get belts (quality for great price) from amazon, here: Amazon com Eureka 4700A belt.
Wish you best of luck.
Ryan
May 29, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka lightspeed dirt comes from underneath vacuum cleaner
Usually this is either a broken belt or a clog in the tube that leads up from the brush head.
Feb 28, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
Change vacuum belt
This unit is not designed for the consumer to change the belt. Eureka recommends you to take it to a service station to have this done
Dec 19, 2008 | Eureka 402A Bagless Upright Vacuum
Eureka 2961AVZ Bagless Upright Vacuum Logo
2,049 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
