Question about Kenmore 40042
We have an older Kenmore front load washer and it has just decided not to spin dry anymore model number 970-C40042-00 Any suggestions?
SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
yalmer
  • 552 Answers
SOURCE: kenmore front load washer Model 970-C40042-00
Click this link.
They will have a manual for you.
Posted on Apr 02, 2008
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
  • 277 Answers
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Mar 02, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
My kenmore 970-38712 washer makes a terriible banging noise on the final spin.
http://www.searspartsdirect.com/model-number/9703871220/0582/0153200.html?searchType=modelSearch&q=970-38712&searchTerm=970-38712
This link shows you your tub parts. There are 2 springs and 2 shock absorbers. Those may be bad broken or loose and one other thing to check is make sure the inside drum has not broken off of the spider assembly in the back. An easy way to check that is open the door and grab the front lip of the metal tub and try to move it up and down, you will notice a huge amount of movement if it is broken loose. The videos I posted apply to all front load washers, The first 2 are great on diagnosing and the last one shows whats left of a broken spider gear. Kenmore Washing Machine Model 970 3871220 9703871220 970 3871220 Parts
If it is the spider support assembly then you will have to replace the entire inner tub and that is about $400 just in parts.
Jan 14, 2017 | Kenmore Washing Machines
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
I have a kenmore front load washer model 970-c42072. I'm experiencing a loud noise in the drum on the spin cycle even when it is empty no matter what setting (slow normal fast) What would be the...
If you turn the inner wash drum by hand, what kind of noise do you hear? If it is a thumping kind of noise, it would mean that the spider support arms are broken. If the noise is a loud rumbling sound, similar to a jet engine when it is spinning, it would mean that you have a bearing seal failure and the bearings need to be replaced. Either problem is a big job to fix since the entire washer needs to be taken apart. Get a few estimates before deciding whether it is worth fixing. Sorry.
Sep 01, 2010 | Kenmore 44072 Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 970-C41062-00 Spin cycle, belt keeps coming off
sounds as if yo umay have a bad rear bearing, and the off balance of it is "throwing " the belt. magor repair, and would ck with manufacture, for possible part warr
Mar 18, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
65 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
