Question about Refrigerators
My subzero icemaker in my refrigeratoer stopped making ice. How can i try to fix it?
  • 348 Answers
Is it making anykind of noise? If it is then you have a ice clog. Take a hair dryer to the ice maker and thaw out the ice causing the stoppage. Sometimes you can feel around for a ice blockage also.
Good luck and thanks for your question and I hope my suggestions help. burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Posted on Jan 03, 2011
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
Subzero 501F icemaker slow in making ice
More thatn likely, being thats an older model, you are low on freom and the temperature isn't cold enough for the icemaker to keep constant production up. You maybe thinking the freezer is fine because stuff is frozen in there but that is why most people don't catch the problem until they lose all their food. The temperature for the icemaker to even come on is 10 degrees F. The sub zero freezer temperature should be around 0. Check your settings and make sure they are turned down but I would get a thermometer and put in the freezer and check to see what it says. If its above 5 degrees F check your condensor coils to make sure they are clean and also see it the condensor fan is running. If dirty, clean the coils and see if the temperature drops, if not call a service company.
May 03, 2012 | Frigidaire Refrigerators
We installed a new subzero side by side 2 years ago and have had problems with the icemake off and on. Now it doesn't make ice and the appliance center does not seem to be able to fix it. The have...
did they check the water valve?does it fill with water?all it does is the ice maker calls for water,the valve fills it,the water freezes,the cubes dump out and it fills again,most of the time it's either the ice maker or the water valve,if they changed the ice maker and the board all that's left is the valve or a broken wire somewhere in the ice maker harness
Feb 11, 2011 | Refrigerators
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have a subzero model 532. I turned off my
its quite possible that your fill tube is clogged with a bit a ice
Oct 09, 2009 | Refrigerators
Air in line to Subzero icemaker
Are you sure there is still water available to the ice maker?
Having a little air in the line might make the water spit a bit but it should be quickly purged and function again.
Also, lift the stop lever on the ice maker inside the freezer compartment, then let it back down to cycle the ice maker and see if that re-initiates the ice making cycle. You'll know because there will be water in the ice tray. It may take a few minutes to cycle.
It's also possible that when the water was turned off and back on, some debris in the water line made its way to the water valve for the ice maker and plugged it. Some units have a screen that can be cleaned, but make sure the water is off to the fridge before disassembling this line and attempting to clean any debris.
If your fridge has a control board on the back of the unit, un plug the fridge for about two-three minutes and then plug it back in to reset the system.
If you did get it to work again, toss the first two to three sets of ice just in case there was dirt in the line.
Apr 27, 2009 | Hotpoint HSS25GFP Side by Side...
Ice in try but not releasing.
unplug the refrigerator remove ice maker melt ice with hot water dont let water get in the wire side of icemaker install unit and plug refrigerato if you have the same problem call service you may have to change ice maker you maynot have shut off ice maker when you shut off the water
Mar 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Feb 03, 2009 | Sub-Zero 561 / F
Subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
Oct 18, 2008 | Refrigerators
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
