Question about Kodak ESP 5 Printer
Our Kodak printer's status says that it is offline but all of the wires are plugged into it. anything i can do to fix it?
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Kodak EasyShare 5500 w. It ill not print, says offline
hi,
in order to fix this problem... do a right click of mouse on the kodak printer icon under printers and fax option. there u will find an option "see what's printing", double click on it and select the option for use printer online. i hope this will fix the issue for you.
Feb 18, 2014 | Kodak EASYSHARE 5500 All-In-One InkJet...
I keep getting the printer status error which I've never gotten before and I can't seem to print on this printer at all anymore. Kodak esp 9 Thanks regards Gary
Hi,, Its a bit difficult to tell why this is happening as I will need a bit more information to help you fully resolve it. But generally the printer status Is if the printer is Online or Offline. this issue is mostly caused by driver failure..
try this fix it should resolve 80% of the issues that cause this.
1.) unplug the USB cable from your printer to the computer.
2.) Right click on the printer in devices and printers (exact spot where you were showing the printer in the vid) and click remove device.
3.) make sure the printer is powered off
4.) plug in the usb cable back into the printer and another usb port of the computer.
5.) turn the printer on.
windows should detect and reinstall a new driver for that printer.
it should work now. If not let me know and we'll go through a few steps to determine whats happening.
Dec 27, 2012 | Office Equipment & Supplies
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Printer offline status
plz try by reinstalling the drivers
Dec 16, 2008 | HP Photosmart C7280 Printer
Kodak Easyshare 5300 Printer
Make sure that 5300 aio is your default printer w/ "ready status" Your HP printer might still be on "default" that's why you're having this issue
Oct 18, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Kodak ESP 5 Printer Logo
1,266 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
