Question about Kenmore 66469 / 66462 / 66464 Microwave Oven
No power; the microwave does not come on when plugged in. Is there a fuse in the microwave? (it is not the main or house circuit breaker.) The power input cord appears to be open when checked with a VOM. thanks
  • 807 Answers
There is normally a fuse inside the microwave. Is there a fuse in the mains lead plug?. I don't know where you are but in the UK all plugs have a fuse fitted. If not it could be the one inside, but it's not something you should really attempt to change yourself. It really should go to a qualified microwave engineer.
Sorry I can't be more help but I'm more concerned with your personal saftey.
Posted on Jul 10, 2008
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
Everytime I turn my microwave on my main circuit breaker trips. When the microwave is just plugged in it turns on , but as soon as it tries to give an output the circuit breaker trips. Could this be a...
You may have either too much also connected to that circuit or the wiring may be involved along with a circuit breaker that needs replacement--you would have to have an electrician look to see if load on it is within limits for what is connected or swap the breaker out with a correct one to see if the issue is the breaker or not.
Dec 10, 2012 | Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
How do you reset the microwave power? Is there an external circuit breaker if the main house circuit breaker did not switch off?
There is an internal cartridge fuse, as well as thermal fuses. It is not recommended that you attempt any internal repairs on a microwave due to the presence of very high voltages and the danger of microwave radiation if not reassembled correctly. Residential microwaves, if not under warrranty, are generally considered disposable. Parts and service are very expensive.
Feb 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our Emerson microwave died and I bought a new one. Plugged it into the same socket and it immediately shorted out and died. After the new microwave died I plugged a blender into the same receptacle and it...
I believe you have a bad circuit breaker or fuse. If you have a delay fuse contrilling this circuit, that would explain the spotty availability of power to the outlet. Also, a faulty circuit breaker can operate in an irregular way, as you describe.
A microwave oven requires a lot of power, relatively speaking. If your microwave is a 1200 watt model, for example it draws 12 amps of power, which could well be almost all of the power available at that outlet, providing that other appliances were not also drawing power from that circuit at the same time.
I can assist you further, but if this information is all you need to proceed that is fine too. Get back if you need more assistance.
Jul 02, 2009 | Microwave Ovens
Replace halogen light bulb inside oven
1 To replace the oven light,
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
4 Replace the screw.
Connect electric
HOPE THIS HELPS :)
Feb 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave lost all power when I pressed start
Plug a lamp into the circuit where the Microwave is plugged in. If the lamp comes on then you know there is power supplied to the microwave and the problem is one of an internal nature. If your light does not come on then your breaker at the main power panel could have tripped. On each breaker is a number which is its rating in amps. Your Microwave may require a 20 amp circuit.
May 11, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore 66469 / 66462 / 66464 Microwave Oven Logo
153 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
