Question about General Electric Water Heaters
WATER IS DRIPPING FROM THE OUTLET VELVE LOCATED ON TOP WATER HEATER.
That sounds like the TP valve is leaking.
http://waterheatertimer.org/Water-heater-leaking.html
1) Leaking TP valve can be caused by defective TP valve
How to replace TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) TP valve can also be caused by overheated tank.
Turn down thermostat.
Install expansion tank on incoming cold water line.
Electric heater: thermostat or element may be bad and tank needs troubleshooting
Gas heater: thermostat is connected to gas valve and gas valve may need replacement.
3) First step is replace TP valve and see if that solves problem.
4) Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Posted on Jan 04, 2011
LINCAT E3BF WATER HEATER
If the pipe itself is protruding more than usual, it sounds as if the tank has corroded around the outlet pipe. If you just mean the pipe coming out of the bottom, you must find the source of the moisture.
It could be a leak on the top or above the tank, or it could be condensation. If it is a leak, it will get worse, and you will know for sure shortly.
Jan 28, 2016 | Water Water Heaters
Corroding top of rheemglas 21vr50-2t
Corrosion caused by condensed acidic water dripping down vent pipe, bad venting pushing acidic combustion by-product out of vent hood, trace chemicals stored in same room as water heater, dielectric corrosion because water pipes not grounded, hot water pipe above tank is not insulated and condensation dripping down on top of tank ... are things that come to mind.
Test venting:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Mar 26, 2013 | Rheem Water Heaters
Electric GE Water Heater Not Heating Water
One possibility: Push in the reset button located on upper thermostat.
Copy following link for troubleshoot walk-thru, and DIY checks:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Nov 04, 2012 | General Electric Water Heaters
Were is cold water inlet and hot water outel on model 71-40d b
Cold inlet and hot outlet are marked on top of water heater.
Usually there is a letter or word embossed into the metal top.
If tank is connected, then turn on hot water tap for a few moment and feel which pipe is hot.
Cold water enters bottom of tank through dip tube located on cold side. If hot and cold are reversed, the water heater will not perform as expected.
http://waterheatertimer.org/Water-heater-dip-tube.html
Aug 05, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
Where can I get a selinoid for a Atwood G6A-4E gas velve?
Open following link for Atwood water heater resources including parts list for different models:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Following link shows ATWOOD Solenoid Gas Valve Type B - 93870
http://www.rvpartsoutlet.com/product_info.php?products_id=6268
Jun 04, 2011 | RTO Atwood Water Heater - 6 Gal LP
My Rheem electric hot water heater occasionally leaks water then stops completely. This has done this three times now over the pact couple years.
It sounds like TP valve is releasing water, but you don't describe where water is located.
Run through process-of-elimination check list on following link:
http://waterheatertimer.org/Leaking-water-heater.html
1) If problem is TP valve, event could be caused by 'stacking'
Stacking is where you draw amounts of hot water many times in succession.
Top part of heater is plenty hot because water heater is keeping up with hot water draw.
Incoming cold water enters bottom of tank through dip tube causing thermostat to read cool temperature and activate burner or element. This causes higher than ordinary temperatures at upper part of tank and TP valve reacts by releasing water.
2) TP valve could be going bad.
3) Improper venting can cause gas water heater to have water on top of tank or dripping down inside tank where it shows on floor after rusting out combustion chamber.
4) Thermostats are old or not reading correct temperature.
Turn down thermostats:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Replace gas valve on gas water heater, and flush tank.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Replace electric water heater thermostats
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Rheem Water Heaters
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
Where is the entrance hole the exit hole on 80gallon whirlpool hot water tank
The cold water inlet and hot water outlet will be located on the top of the water heater. On the lid they will be marked with a H for hot and C for cold.
Oct 02, 2010 | Whirlpool Water Heaters
Installed new water heater today. No problems,
did you place Teflon tape around the outlet nipple? you might have to remove and wipe off thread then reapply Teflon tape then put a layer of gasoila pipe dope over the tape then make sure it is the female adaptor is cranked down tight
Jul 12, 2009 | Water Heaters
Water Heaters Logo
137 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
