Question about M&S Systems M S Systems Room Station RoughIn Kit 5 Pack
On the M&S Systems intercom what does RELS indicate? It alternates with the time on the digital readout. How does one clear it?
  • jadru3 Mar 23, 2011
    Hi s80captn, did you ever get an answer to this question? It's driving me crazy! Thanks Joe
2 Suggested Answers
technical114
  • 1851 Answers
SOURCE: I can not get the
Here is a part of the user manual:
OPTIONAL DOOR RELEASE - always active. If the system is set up to
use the Door/Gate release function, the VOLUME UP button and VOLUME DOWN
button are used to open the Entry Door or Gate. The Door/Gate release is activated
by pushing both the VOLUME UP and VOLUME DOWN buttons at the same time and
holding them for 4 seconds. The display will show "door" when the buttons are
pressed at the same time and it will show RELS when the door release is activated.
In case you need the full manual here is a link for you to get it.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 07, 2011
Master Unit M&S System displays REL 5
This actually means RELS which stands for release. There is typically a bad room station that has a broken button, or button stuck. To troubleshoot, remove all black wires from the master unit. Any display of RELS or clicking sound should stop. Add back the black wires one by one until the issue of RELS occurs again. If so, do not attach this wire and hook up all remaining wires. If the user wants to know which room station this is, go from room to room and press the listen button. If the music is muted, the station is good. If the music continues, this is the bad room station. Unfortunately, these room stations are no longer available. Visit our website for replacements parts and products, or if you have more questions.
Intercom Systems
Don't forget to visit and like our Facebook page https://www.facebook.com/QualityHomeSystems
Feb 27, 2015 | M&S Systems 3- Or 4-wire Retrofit...
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
How do I reset time and date
Which system do you have? Below are the Panasonic systems. Be sure you find yours.......
Panasonic XDP 824/1232
All programming is done at ext. 101
1) Press the program button, followed by *#1234
2) Dial 000, then follow the prompts on the LCD
KX-T308, KX-T616
  1. Use phone with intercom number 11. It will change the time for all phones.
  2. Keep handset down and press INTERCOM button.
  3. Dial 77.
  4. Dial the hour, with two digits (e.g. 03 for 3 o'clock).
  5. Dial the minutes, with two digits (e.g. 07 if it is now 7 minutes after the hour).
  6. Dial 0 for AM or 1 for PM.
  7. Press #.
  8. Press SP-PHONE
Panasonic KXT Series Telephone System
Setting the time must be completed from an LCD Display phone at Extension 11, using the telephone keypad. This system type requires "Easa-phone" series or a 7000 series model telephone (the model number is listed on the bottom of the phone) that has one or more small switches located at the rear of the phone. Digital "XDP" phones can not be used on this system type!
To set the time:
  • Lift the handset or press "SP-Phone" button on Extension 11.
  • Dial "77"
  • Enter the hour with 2 digits. (01 through 12)
  • Enter the minute with 2 digits. (00 through 59)
  • Dial (0) for AM or (1) for PM.
  • Press the "#"
  • Wait for confirmation tone. (Instantly after pressing the # button, new time counting will start).
KX-TA624
  1. Use phone with intercom number 101. It will change the time for all phones.
  2. Move MEMORY switch on rear from SET to PROGRAM.
  3. Dial *#1234
  4. Dial 000
  5. Press NEXT ("Sp-phone")
  6. Press Right Arrow ("FWD/DND") four times until you see the time displayed
  7. Change the hour with the keypad
  8. Press Right Arrow ("FWD/DND") to reach the minutes field
  9. Change minutes with the keypad, if necessary
  10. Press AUTO DIAL/STORE
  11. Press HOLD
  12. Move MEMORY switch on rear from PROGRAM to SET.
KX-TAW848
  2. Press PROGRAM (or PAUSE, if you don't have a PROGRAM button.)
  3. Dial programming access code (probably *#1234)
  4. Press NEXT (SP-PHONE, if you are not using the programming template).
  5. You'll see "Date & Time Set" on your phone's display
  6. Press STORE
  7. Press NEXT to see hours and minutes.
  8. Use your keypad to change the hour
  9. Press STORE.
  10. Press HOLD.
  11. Press PROGRAM
KX-T123211D
  1. Use phone with intercom number 101 (probably the receptionist's phone). It will change the time for all phones.
  2. Move MEMORY switch on back of that phone to PROGRAM.
  3. Keep handset down and press 0 on touch-tone dial.
  4. Dial year with two digits (e.g. 97 for 1997).
  5. Dial month with two digits (e.g. 01 for January).
  6. Dial date with two digits (e.g. 03 if today is the third day of the month).
  7. Dial day with one digit (1 for Monday, 2 for Tuesday, 3 for Wednesday, 4 for Thursday, 5 for Friday, 6 for Saturday, 0 for Sunday).
  8. Dial hour with two digits (i.e. 01 for 1 o'clock).
  9. Dial minutes with two digits (i.e. 07 for 7 minutes).
  10. Dial 0 for AM, or 1 for PM
  11. Press either AUTO DIAL/STORE or AUTO/MEMORY, depending on your phone.
  12. Move MEMORY switch on back of phone to SET.
Panasonic DBS 824, 40, 72 & 96
- From the Attendant's display phone.
  1. Press "On/Off"
  2. Press "Prog"
  3. Press " ##"
  4. Press "FF1 key"
  5. Dial 1#, 2#
  6. Dial the time in 24 hr format.
  7. Press #
  8. Press "On/Off"
- From any display phone in the system.
  1. Press "On/Off"
  2. #98 + Password
  3. Press "Prog"
  4. Press " ##"
  5. Press "FF1 key"
  6. Dial 1#, 2#
  7. Dial the time in 24 hr format.
  8. Press #
  9. Press "On/Off"
Panasonic DBS 576 & 576 HD
From any display phone in the system;
  1. Press On/Off
  2. Press "Prog"
  3. Press " * * "
  4. Dial the " Password"
  5. Press "FF8"
  6. Dial 81001
  7. Dial in new time in 24 hr format.
  8. Press Hold and then "On/Off"
Aug 19, 2010 | Panasonic KX-T7731 Corded Phone
How do you change the time on the phone system ?
Toshiba 2000 series phones can be used with a lot of different Toshiba systems. With that in mind, this should cover your system.
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered, press Redial, press Speaker.
This must be done at extension 200 – usually the receptionist phone. For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker.
Jul 01, 2010 | Toshiba DKT2010SD Phone
How do I change the time on an office toshiba dkt2010-sd telephone. I looked in the online manual and cannot find the answer. Thanks
There a few different types of systems that work with that phone. I'm guessing that its either going to be a dk 40i or dk 280.
Leave the handset2.gif on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered, press Redial, press Speaker. This must be done at extension 10 – usually the receptionist phone. For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker.
Nov 07, 2009 | Toshiba DKT2010SD Phone
NEED TO CHANGE TIME ON THE PHONE...HELP
Leave the handset on hook, press intercom # 6 5 2, then enter the time of a 24 hour clock, entering 2 digits for the hour, 2 digits for the minutes, and 2 digits for the seconds – enter a leading 0 for any single digit entered, press Redial, press Speaker. This must be done at extension 10 – usually the receptionist phone. For example, if the time is 2:15 P.M., press intercom # 6 5 2, 1 4 1 5 0 0, Redial Speaker.
Nov 06, 2009 | Toshiba DKT-2020-SD telephone
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
M&S Systems M S Systems Room Station RoughIn Kit 5 Pack Logo
296 people viewed this question
Top M&S Systems Home Security Experts
Lawrence Oravetz
Are you a M&S Systems Home Security Expert? Answer questions, earn points and help others
