Question about Avermedia AVerVision CP150 Document Camera
Color display is only showing green light - Avermedia AVerVision CP150 Document Camera
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Acer 2016W - When powered on, it shows colored lines (blue, green, red, yellow - vertical) and then goes to a blueish-green display color, no deskktop display at all, have tried switching out monitor...
Yep,
When the capacitors start to go out it causes the power supply to not provide the correct voltages. You monitor has the back light power but the 5v power going to the video driver board is not working correctly. Here is a link to a repair guide that will show you how to open the unit, remove the power supply board and what capacitors need to be replaced.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2016w-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 13, 2011 | Acer AL2016W 20" LCD Monitor
My KDS-55A2000 displays some shades of blue as green. It's not just one area of the screen but the entire screen. Flesh tones can be adjusted to look pretty normal but scenes with light blue sky look...
Your t con board is responsible for the image on your screen. Your colors are all there but they are f---ed up in certain scenarios.
That is the only board on your set that be causing this anomaly.
Apr 30, 2017 | Sony KDS55A2000 55" HDTV
My other computer, G4 Macbook Pro, has a screen issue. When it is turned on and in process of coming up, the screen shows large sections of odd colors such as light pink or light green or light blue. Then...
Connect an external display to the computer. If the lines and distortion shows up on the external display its the video card, which is attached to the logic board. So, the whole logic board will need to be replaced.
If the lines and distortion don't show up on the external display the issue is the LCD module, which will need to be replaced.
Jan 30, 2011 | Apple PowerBook G4 Mac Notebook
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Monitor Problems
1. check the monitor on other PC if the problem is same that means the VGA cord or the Pins have gone faulty.
2. Just bend and cable and keep monitoring the display where it stablises to normal, and tie thw cacle at that point with something.
Apr 29, 2008 | Computers & Internet
No display on screen
Is the Displays power light colored "Green" or Amber ??..if its Green then its getting a signal and maybe you have a Bad Display.
First, check the cables to make sure they are intact. If nothing shows up. then boot the PC and use a shine a flashlight on the Monitor to see if you see any text. if you do see text ..then your Backlight is bad. If you dont see anyting you may have a Bad video card.
hope this helps,
djEnigma
Apr 10, 2008 | Computers & Internet
Benq 7220 display wrong color
It sounds a lot like a bad color wheel if it was a DLP. IF it is a LCD then i would say one of the LCD panels is bad or possibly a connection problem that drives the panel or the connection that hooks up to the projector is suspect. Let me know if that helped you at all.It is strange that the bottom shows white though. Jay
Jan 30, 2008 | Office Equipment & Supplies
Avermedia AVerVision CP150 Document Camera Logo
200 people viewed this question
Top Avermedia Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Avermedia Office Equipment and Supply Expert? Answer questions, earn points and help others
