Question about Lexmark Wheelwriter 1500 Typewriter
Correction tape I replaced the correction tape, but the new tape isn't working. Any ideas?
  • Lexmark Master
  • 3,594 Answers
Does the correction tape move? Does it lift up to the proper height? If it does both of these try advancing it a few inches the tapes get old and the exposed portion won't work. If this helps but it isn't real good get a fresh (not one that has been sitting on the shelf for years and thes will help.
DickyO
Posted on Jul 11, 2008
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
Minutes left on tape not displaying
Is it when you do playback on tape or when you do a recording
Dec 09, 2011 | Sony Video Cameras
The magenta isn't printing correctly, and the printer keeps telling me to remove tape from the magenta cartridge. There isn't any tape on it. I've tried resetting it several times.
Its sounds as though the printer isnt picking up the cartridges properly, try removing it and cleaning the contacts on both the cartridge and the printer
May 05, 2011 | Dell 3130cn Color Laser Printer
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
The correction feature just stopped working. Ther...
Go to broyher.com, click on support you will find a manual there.
DickyO
May 20, 2010 | Brother SX-4000 Typewriter
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
May 29, 2009 | Olympia Mastertype 3 Typewriter
Brother EM-530 corrective tape appears to be broken
Be sure the tape is installed with the dull side facing the platen. The tapes are readly available but be sure it is a dry L/O tape General ribbon T355 or equivlent.
DickyO
Jan 29, 2009 | Brother EM-530 Typewriter
IBM Magstar 3590 FID1 B4 error
Check Tape Path A sensor is working correctly, if ok.
Then the pantocam (tape threader assy) will need replacing.
Dec 31, 2008 | IBM Magstar 3590 Magstar Tape Drive
EWC1304 VHS tape shuts off entire system
You probably have a bad or dirty mode select switch. Another possibility would be a gear out of time if a tape was forced in too quickly.
Mar 12, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Lexmark Wheelwriter 1500 Typewriter Logo
162 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
