Question about Lexmark X4650 InkJet Printer
Will copy only in color, not black and white - Lexmark X4650 InkJet Printer
    Genius:
  • 1,087 Answers
Make sure the black and white button on the printer operator panel is lit. Then, check the black ink level by pressing the Setup button on the printer operator panel -> Maintenance -> Ink Level -> Black. If ink level is substantial, try to remove the black cartridge from the printer and wipe the nozzles with a moistened soft cloth. Reinsert the cartridge. You can also do the Clean Cartridge function by pressing the Setup button -> Maintenance -> Clean Cartridge. If these don't help, try to replace your black cartridge with a different known working black cartridge. I hope this information has been helpful.
Posted on Jan 10, 2011
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
My printer copy's in color but prints photos in black and white,
Check your settings for your printer software program, change it to black and white, and then you will need to change it back to color, if you want to print in color.
Aug 10, 2009 | Office Equipment & Supplies
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Copies
Hey :), I'd be happy to help. To make a copy you must lift the lid and lay down the item you want copied. And then on the side of the printer you will see a line of buttons , to copy the item you want,you have to let the printer know if you want the copy to be in black and white or color .To let the printer know of you want the copy to be in black and white or color, you have to select/press between the black ( black and white ) button in the line of buttons or the color button. Once you press wither of these buttons/options , the printer will automatically start the coping process. thanks! I hope this helps :)
Oct 11, 2008 | HP PSC 1315 All-In-One InkJet Printer
DVD output is Black & White
What type of machine is doing the copying?
Feb 27, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
Lexmark X4650 InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
