Question about Karcher 2500 PSI Pressure Washer
Won't run with air filter on
My pressure washer won't stay running with the air filter on. It will run for a minute or so but then dies. Both the air filter and pressure washer are brand new with only about 2 hours of use.
  • Anonymous Jul 10, 2008
    Stored pressure washer for one year, went to use it and it won't keep running. We have replaced float valve and cleaned the carburator. Engine will run with float valve off, but will only run a few seconds with it on. Can anyone help ?
I have a fairly new pressure washer with the same problem and discovered that because it was temporarily stored on its back (rather than upright), oil seeped into the air filter housing. If you look at the air filter it may not look like it has oil on it - especially if the oil is new. Mine runs fine without the air filter, but as soon as I put it in, it does the same as yours. I came across this site since I am looking to order a new filter. Hope this helps.
Posted on Jul 13, 2008
New batt new alt 92 izuzu wont stay running
check fuel filter ,pump ,pressure .
Mar 04, 2015 | Cars & Trucks
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
Car won't stay running
did you give it a tune up change plugs fuel filter
Feb 17, 2013 | 1987 Oldsmobile Toronado
1997 geo prizm won't stay running sputters and dies upon acceleration
If the check engine light is on you should have the computer scanned for trouble codes. The codes will direct you or a mechanic on where to look for the problem.
Sometimes the problem is low fuel pressure or a dirty fuel filter.
Jan 13, 2013 | Cars & Trucks
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
Pressure washer turns off after 3 or 4 minutes
does the engine die or the pressure if its the engine leave the gas cap loose and see if it stays running the vent could be plugged is it loosing spark when it dies check it for spark is it fuel does it fire back up or does it need to cool off for a while like the coil is bad
Apr 26, 2012 | Honda 13 Hp 4000psi 4gpm Pressure Washer...
My pressure washer starts fine but after you run
HAVE GX390 RUNS ON LOW IDEL THAN DIES ON HIGH NEW GAS
Feb 20, 2010 | Honda Pressure Washer PSI 3000
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
Jul 05, 2009 | Karcher 2500 PSI Pressure Washer
2001 checy Tahoe wont stay running for more then 10 seconds?
hi i have a 1997 chevy tahoe that starts but won't stay running i have changed fuel pump, fuel filter,relay ,spark plugs, and just changed rotor and dis. cap ready need some help to figure this out please.
Jan 31, 2009 | 2001 Chevrolet Tahoe
Stalling
likely you air to fuel ratio is too lean, runs mean and hot but under load dies. then floods the carb.
when it happens pull the plug ,
kill engine :
is there a lot of gas or none.
remove the filter and watch the action of the carb does it open and close easily is the filter clean.
try supplying it more gas turn the gas supply screw 1/2 CCW and see if it will stay running, if not add more.
( NOT the idle screw on the carb side w/spring )
By the way did a bit of water come out if not the clutch/pump may be binding or stuck with soap goop.back flush with hot water.
Apr 13, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
396 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
