Question about Ectaco jetBook
My jetbook mini usb cable will not show up on the computer screen when i plug it in. the card shows up and seems to download - says the book is in there but i cant find it in my jetbook. it is a brand new jetbook and i downloaded a book from deisel - a recommended store. could it be because i have a vista computer or my cable is no good - my card seems to be ok though. i have already pressed the reset button in the back and held the on off switch for 3 seconds.
3 Suggested Answers
  • 1796 Answers
SOURCE: Plugging in the USB cable to connect Ectaco
Hi!!
Download and install the driver from the Ectaco jetBook site and you'll be OK.
Don't forget to rate this post!!
Posted on Sep 28, 2010
  • 5 Answers
SOURCE: My Ectaco jetBook does not fully charge. Even
If your jetBook is fairly new, I would check the warranty information and it may be able to be fixed. It sounds like the battery is defective, or is wearing out. If it is not under warranty however, replacement batteries can be found for around $20 here :http://www.google.com/products/catalog?q=ectaco+jetbook+battery&um=1&ie=UTF-8&cid=5694578107145482203&sa=X&ei=T3G_TZ_2LM-9tgej1dWqBQ&ved=0CGgQ8wIwAQ#
Posted on May 03, 2011
I have a problem with a Zen PMC 20GB. When I reset the device using the pinhole reset button, the unit goes off and then comes on with the "Creative Logo" and then it goes to a diagram screen...
  1. Turn off your player
  2. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  3. Power on the player
Oct 09, 2008 | Audio Players & Recorders
Tip
How to change a JeetBook LCD Screen
<p>The jetBook is an electronic book reader, similar in size and appearance of a Kindle. As with other e-book readers, on the front of the unit a sleek LCD screens. If the LCD screen on your jetBook as torn or damaged, and you do not want an entirely new e-reader to buy, you can replace the unit and the display itself <br /> <p><br /> <p>1. Turn jetBook and close the device. Use your screwdriver to remove the screws on the sides and corners of the rear panel. <br /> <p><br /> <p>2. Pry the back of the front half of the unit. If necessary, insert the tip of a screwdriver into the connection between the back and front of the unit and work around until the panel concluded. <br /> <p><br /> <p>3. Lift the motherboard and turn the front of the house. The LCD screen is now visible on the board. <br /> <p><br /> <p>4. Lift the LCD monitor and pull the cable out of the gate of the plate surface. <br /> <p><br /> <span>5. Remove the LCD and set aside. </span>
on Jun 22, 2011 | Televison & Video
I have just started to use my JetBook (SNJB507670) and have two problems. Note that my computer is a MacBook using Tiger O/S). 1. The computer doesn't seem to be aware that there is a 2 Gigabyte SD card...
You have indicated that you have just started using the device. I would assume that you have just purchased it. It would be best if you take it to the store and have them check it. Normally if an SD card is plugged in nothing has to be dont to have it recognized.
Aug 07, 2008 | Ectaco Computers & Internet
I have a new mini jet book and trying to download ebooks having difficutly Pls help
Hi, to download books you have to make sure they are in TXT of FB2 format. First check the format of the book you are trying do download. If it is a different format you can easily convert it with Calibre converter. You can do a Google search for this eBook converter software.
After you have a book in this format move it from your PC to the jetBook using the cable provided. Or you can put it on an SD card and insert the card to the device.
Dec 20, 2010 | Ectaco jetBook
WD MyBook Premium not showing any capacity using Firewire
There seems to be a firewire port issue on the device. Why not leave it USB?
Jun 05, 2009 | Western Digital My Book Essential Edition...
Westinghouse DPF-01411 Digital Photo Frame
Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
Mar 30, 2009 | Westinghouse DPF-1411 Digital Picture...
O2 xda 2 mini pocket pc usb connection problem
how i get my o2 xda ii mini drivers?
Aug 12, 2008 | O2 Xda II mini
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Ectaco jetBook Logo
Top Ectaco Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you an Ectaco Office Equipment and Supply Expert? Answer questions, earn points and help others
