Question about Saeco Magic Comfort Plus Espresso Machine
I took the mechanism out to clean it and now I can't get it all the way back in (the door won't shut). Any ideas?
  • ingridembree Jan 04, 2011
    Unfortunately, none of those instructions seem to fit my brew unit. The Magic Comfort Plus doesn't have a screw on its brew unit, and there are no horizontal bars on the brew group.
    I did close the door without the brew unit, turned it on, and tried again, but same problem. It doesn't allow the door to close.
  • 1,089 Answers
Hi
You can read the last part but it might be better to read the whole thing.
Remove the dredge drawer. Open the right side door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the PRESS button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group. If the brew group doesn't lock in, push on the upper left side until it clicks. you may have to lubricate the outlet pipe that goes into the machine, with a food grade lube, not food based.
Done
Posted on Jan 03, 2011
Door won t stay closed
The door catch is down or has lost a spring inside the hook
No simple fix but too replace door latch inside
In order to drive car with door that way no back seat passengers till fixed but use tie down ratchet straps from door to door inside handles
This will keep door shut then can drive vehicle normal till door catch is fixed its simple hour job to replace just buy parts have mechanic shop install
Sep 08, 2014 | 2000 Toyota Camry
Model GDM-69
A GDM 69 three doors. Each door closes using a string attached to a weight, which runs through pulleys or copper tubing, and is held to the top of door. The pulleys or copper tubing can be accessed by removing the aluminum siding located inside cabinet on either side. The left side contains the pulley and weightfs or left and center door, the right for right door (each held on by 4 1/4 screws) . To make the door close, simply make sure string is attached to weight, running though pulley, and attached to top of door.
Nov 07, 2013 | True Refrigerators
2001 Town and Country 3.8 When I open the driver's side door the alarm will go off and won't stop until I start the car.
There is a 2 wire switch that goes on the backside of your door lock cylinder. Prob got knocked off when u were in there. Till u can look just unlock the pass door or the lift gate with key and that will shut alarm off
Apr 19, 2013 | 2001 Chrysler Town & Country
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
2006 Chev Impala - back driverside door won't open from inside or out.
take the panel off the other side door and have a look and compair the two, though there is a small part between the two mechanisms that maybe missing
Jun 11, 2012 | 2006 Chevrolet Impala
Toyota sienna 2008 sliding door won't shut
Try lubricating the door latch in the door. You can also use a screwdriver to see if you can get the mechanism to move freely.
Sep 14, 2017 | 2008 Toyota Sienna
My toro 6.5 hp push mower (2010), has no fire to the plug. I have not abused it. i have a small yard and it just gets normal use. Now it won't fire. I first changed the fuel and cleaned the carb...
unhook your wire from the coil that goes to shut off mechanism, and see if you have spark then. the wire may be grounded out, or your coil might have took a ****
Aug 02, 2011 | Toro Power Lawn Mower
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 | Ovens
Doors won't open
Jakenju, I would bet that the rod from the outer door handle is either off at the handle or the door latch on the pass door. Mayhap exact same problem on rear door.
Aug 22, 2008 | 1997 Toyota RAV4
Saeco Magic Comfort Plus Espresso Machine Logo
81 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
