Question about Smith Corona Wordsmith 100 Typewriter
Carriage Return doesn't work. Everything else works fine; but it will not return the carriage when the return key is used.
  • Anonymous Oct 04, 2008
    I can't clear the current margins to set new margins either. Code + 1 are supposed to clear old margins, but backspace and space bar won't move the carrier beyond the current settings.
  • 183 Answers
Check to make sure no forien objects are in machine preventing the carrier from moving, with the mach. turned OFF you should be able to move the carrier by hand from one side to the other
Posted on Nov 25, 2008
Cannot unlock the carriage
There is a little lever under the carriage on the left,used for locking the carriage when in transit.Move the lever in the opposite direction,if that does not work press the Capital Lock Key then try it.If this does not work,it will be your carriage return spring having lost its tension.This is the round drum(wheel ) on the back of the carriage connected by a cord.
Oct 29, 2011 | Olivetti Lettera 25 Typewriter
My carriage return is stuck between 70 and 80 and I don't know how to get it back to 0 to 10. I hit return and the carriage goes back to between 70 - 80.Can you help me?
Return to the L. margin, touch and release the mar rel key, backspace to where you want the margin, press L. mar. key.
May 20, 2010 | Nakajima AE-710 Typewriter
AE-710 Typewriter: My carriage return is stuck between 70 and 80 and ...
Return to the L margin, press don't hold the mar rel key, backspace to the desired location, press left mar. key. The R. margin works the same.
May 18, 2010 | Nakajima AE-710 Typewriter
IBM Selectric III correcting. Carriage return and
You most likely have a broken torque limiter tension spring. We have them in stock but tou must have a good mechanical ability to install.
Jan 29, 2010 | IBM Office Equipment & Supplies
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
Dec 08, 2008 | Office Equipment & Supplies
Carriage return not working
Turn off T/W and see if the carrier will move back and forth freely, if so try removing the batteries and unplugging the machine this will reset to defalt settings. CAUTION THIS WILL ALSO CLEAR YOUR MEMORY!! If the carrier is hard to move a little light oil on the shaft it slides on may cure the problem.
Mar 25, 2008 | Lexmark Wheelwriter 35 Series II...
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Smith Corona Wordsmith 100 Typewriter Logo
394 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Keysor
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
