Question about Hotpoint RGB528 Gas Kitchen Range
Hotpoint electric igniton oven
After recently having my new kitchen floor done and the oven disconnected, I now have a problem with the oven heating. I can get the burners to work and the broiler but the oven will not heat. Could you give me some idea of what to check? Thank you. Diana
  • 770 Answers
First off is the glow bar getting hot it will glow a bright orange before it will light the burner these are very fragile so if the oven were dropped or hit hard it maybe broken
Posted on Jul 09, 2008
Oven shuts off after closing door
Have you put a thermometer in the oven to make sure it is not heating. They will not always glow red if the oven is at temp.
Feb 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Getting tu the heating element on a maytage oven model #mer5755qab how do I get to that element . is it on the top or under the botto,
Hello Jerry,
That bake element is accessed from under the floor of the the oven...in th erear of the floor is a couple screws if ya remove those ya can pull up the the oven floor up and out from the rear to the front the bake element will under of that floor.
BEFORE ATTEMPTING THAT BE SURE TO DISCONNECT POWER TO THE OVEN
Sep 30, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Oven takes 30 minutes to heat up to 350 degrees
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 25, 2011 | Hotpoint RB757 Electric Kitchen Range
Oven will come up to preheat,but will not maintain temp. the ignitor will come back on but burner will not light again.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 04, 2010 | Hotpoint RGB745 Gas Kitchen Range
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Stoves newhome
the residue is the grease being exhuasted from the oven.i wouldnt think you could vent it out unless you have an overhead hood.if its really bothersome look at a home depot/lowes for a heat/fire resistant filter and install it on the oven somehow.
Jan 05, 2008 | Stoves 800DFDOm Dual Fuel (Electric and...
Hotpoint self-cleaning oven
  I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
Oven and smooth top no functioning
Sounds like a breaker issue to me. The breaker for this one should be located outside (if you're in a home) near the electric meter. Open the breaker box and look for a 40 or 50 amp breaker set (your oven uses 2 separate breakers, they are side by side in the box). Even if they don't look "tripped", go ahead and trip them manually and reset them. This should get you cookin' again. *Note--> Breakers can get "weak" and trip for no reason. If this continues to happen, you should have an electrician replace your oven breakers.
Sep 05, 2007 | Hotpoint RB787 Electric Kitchen Range
Electric Oven very slow to heat
cheak for 240 volts coming out of your wall if it reads 120 volts it is your house breaker
Nov 26, 2006 | Hotpoint RB757 Electric Kitchen Range
Hotpoint RGB528 Gas Kitchen Range Logo
315 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
