Question about Microsoft Windows XP Professional for PC
Everytime i open the computer it reads the feature you are trying to use is on a cd rom or removable disk insert the aiosotwarenpidisk
  • Microsoft Master
  • 3,287 Answers
"AIOsoftwareNPI" is included on the CD that came with your HP All In One printer. Place the HP All In One disk into the optical drive (CD / DVD ROM drive) and restart the computer. "AIOsoftwareNPI" will automatically be installed after boot.
If unable to locate the ****, go to HP's website to download the disk for your particular All In One printer.
I hope this helps. Please rate my reply - thanks!
Posted on Jan 03, 2011
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Dvd/ cd rom does not read any cd/dvds (not even blanks or store bought) under my computer there is dvd drive there. everytime i click on it, it says to insert an disk, even though there is already an disk...
Sadly it sounds as if the drive has died/is dying. You could try cleaning the head with a CD/DVD head cleaner, as sometimes you can get a tiny piece of dirt on the lens. Another method to try is to blow hard (but avoid spitting!) into the open DVD tray, which can sometimes dislodge any dust. If all these fail, open the case, and check that the cables are securely attached.
Sadly, if none of the above work, the only likely way is to replace the drive itself.
Aug 31, 2011 | Dell Inspiron 531s Desktop Computer
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
CD tray opens and shuts fine. With CD loaded and shut the screen still says NO DISK. These are disks which have always played without problem on this CD player. Is there anything I can try before taking...
When the CD player loads properly and still reads as no disk this indicates that the player lens (Optical device which reads the disk information) Is either dirty or bad. The only option you have is to get a disk lens cleaner and run it on the system. Once you run it, it is supposed to work if the lens is not spoilt. Otherwise you will just have to replace the lens by taking it to a repairer.
Hope this solution has been helpful?
Jan 17, 2011 | Audio Players & Recorders
When i put a disk in the cd rom keep getting message please insert disk
Try known good disk. Other than that the unit has probably failed. Make sure disks can be read on a buddys computer?
Jul 28, 2009 | Dell XPS 400 PC Desktop
CD not being read from CD/DVD ROM Drive on Laptop
try to clean the cd drive lens with a lens cleaner...
Jan 30, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Dvd/cd rom drives
i cnt run my dvd rom drive but only cd.disk
Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
Microsoft Windows XP Professional for PC Logo
175 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
