Question about Hitachi CP-X251 LCD Projector
When I hook my Hitachi up to a mac pro with a LED Cinematic display. The display on my monitor changes to a smaller resolution and I can't increase it to normal. When I unplug the monitor it works great.
  • mhinze356 Jan 11, 2011
    Thanks.. I will try this at work tomorrow!!!
  • 107 Answers
Here you go, the solution to your problem is right here on this site, and it shows you exactly what steps to follow to get your preferred resolution.
http://myweb.wit.edu/dts/docs/LCD_Macs.pdf
Posted on Jan 03, 2011
Hitachi 32 LED TV not filled screen when connected to mac
Change settings on your pc for a second screen, it is in the display section under control panal.
Feb 26, 2014 | Hitachi Televison & Video
My acer windows are too large and I can't get to the apply or ok button to changed the settings
Click Start/Control Panel and look for Display or Appearance and Personalization. Open the Display then select the Settings Tab. Increase the Resolution. The higher the resolution, the smaller the icons, the more will get on the screen.
Apr 29, 2012 | Acer Aspire Computers & Internet
How do I increase screen resolution in PC mode running Windows XP Pro?
To change your monitor's resolution
1. Right-click the desktop, and then click Properties.
2. In the Display Properties dialog box, click the Settings tab.
3. Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4. Click Apply to have the new resolution take effect.
5. If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6. Click OK.
Hope this help.
Mar 21, 2011 | Computers & Internet
I have the HannStar Model #HC194 hooked up to my MacBook Pro. I know the Mac is recognizing the monitor, because when it's hooked up, the hard drive icon disappears and reappears on the Mac when the...
The clicking noise is a hard drive noise and not associated to the monitor. Likely going bad. Maybe an external? The monitor issue being black may be related to the resolution or the "Mhtz" that the display is set at (forgive the grammar). First go into "System Preferences" and change the resolution to a lower resolution. If that works then you can see about further adjustments from there modifying as you need till you get the best results.
Jan 05, 2018 | Hannstar I-Inc iF191DPB 19" LCD Monitor
I'm trying to hook up my Westinghouse L2410NM 24 inch monitor to my MacBook Pro. I'm using the DVI adaptor for my mac to connect to the monitor via an DVI-HDMI cable. My mac seems to detect the L2410NM,...
You need to change the refresh rate, some monitors operate on 60 Hertz, and others on 70 or 72 Hertz, try changing the refresh next to the resolution choices.
Nov 13, 2010 | Apple MacBook Pro Notebook
The display screen got smaller.How can I bring it back to normal size?
You have to change the resolution of the screen.
Right click on the desktop, not on an icon- Properties- settings- at the "Screen Resolution" box increase the value.
7fb4f63.jpg This picture is for Windows Xp.
The following is for Windows Vista:
28993d7.jpg Select display settings and a window almost the same will appear. Again increase the value.
If you need further assistance, just post a comment.
Mar 29, 2010 | E-Machines eMachines Monitor E15T4
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Hooking up a Mac to tv
I ran into the same problem with my "50 maxent. The manual clearly states that mac resolutions are not supported. We won't let that stop us. Step one is to download switchresx. It's a simple utility that should allow you to define custom resolutions. http://www.madrau.com/ .
Step 2 is to download chicken of the VNC. http://www.macupdate.com/info.php/id/9517 . Once this is installed on a separate mac from the one you are trying to connect to the maxent take your mini and hook it up to the RGB port on the maxent and boot it up. Once this is done use chicken of the vnc to take control of of the mini with the other mac. Now you can change the resolution on the mini using switchresx which you installed on the mini earlier. In the case of the maxent you will need to set it to 1366x768 at 60 hz. If using another flat panel consult your user manual for the correct resolution. In my opinion there is no flat paned tv this should not work for.
Sep 30, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
MacBook Pro (Leopard) doesn't regconize the projector when on (No input)
You must make sure the Mac resolution is set to 1024 X 768, otherwise it won't be recognized by the PG M20X Sharp projector. This change in resolution will cause the screen size to get smaller on the mac but, it will allow the projector to recognize the computer.
Sep 10, 2008 | Sharp Notevision PG-M20X Multimedia...
How do I increase the size of my desktop and remove the blue border?
There are three size settings you can choose from, Normal, Wide and Zoom. Try changing it using the 'Size' button on the remote or by going into the On Screen Display (OSD) settings. If you don't have a manual you can get one here. Hope this helps.
Mar 14, 2008 | Samsung 192MP (Silver) 19" LCD Monitor
Hitachi CP-X251 LCD Projector Logo
118 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
