Question about True 31 cu. ft. / 878 liter Upright Freezer TR1F-1S
I am looking for relacement wheels. - True 31 cu. ft. / 878 liter Upright Freezer TR1F-1S
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
just contact true at http://www.truemfg.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
Wheel for move refrigertor
If you want wheels you can order them from True Mfg.
Jul 16, 2014 | True Display Refrigeration GDM-41 - White
Relacing freezer bulb in Whirlpool upright
Screw out the bulb or unplug and take it with you to the store to purchase a new one. reinstall in reverse order.
Nov 01, 2013 | Whirlpool 19.6 cu. ft. Upright Freezer...
Leveller
Check the wheels as they may either turn to go up and down or there may be a screw that does this adjustment. Place a level on top of unit. Get one direction level then do the other. May only have to adjust one wheel/leg to get unit level.
Apr 22, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
How do i replace a wheel on a beverage air freezer
For Service Call (877) 866-1223 Beverage-Air Corporation Offices: 3779 Champion Blvd., Winston-Salem, PA 15825
_________ Manufacturing/Shipping/Receiving: Brookville, PA 15825
Contact with Model Number and Serial number for assistance
Beverage Air
Sea Breeze
Feb 26, 2013 | Freezers
What could be causing my 7 year old upright Frigidaire Model FFU21K2CW0 Freezer to NOT freeze? The inside (of the compartment) coils feel cold, the seal is good, but the ice cream is VERY soft. The...
Your freezer is probably running constantly as well. Lift the bottom vent panel (the one with all the holes in it) and look at the bottom of the back panel. There should be a half inch gap for the cold air return. If you see a solid wall of ice in that gap your coils have frozen over. You need to clean out the freezer and defrost it. Look in the back near the compressor. If your model does not have a drain plug in the bottom then you need to leave the door open and mop up the water as it melts off the coils from the inside. If you can, wheel it outside on a dolly and let it defrost where it can drain on its own. After you are sure it is totally defrosted, plug it back in at a control setting of 5 for at least 4 hours, preferrably overnight, and check the temp. Setting the freezer at 7 will encourage ice buildup. Your problem may be a bad defrost timer, which your local appliance parts store may have.
Aug 03, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I bought a soft serve taylor 754 machine. when shipping arrived, the wheels are broken off. Now I need to replace wheels. do you carry those wheels for that machine? and if so what are the prices
I use Restaurant Parts and More out of Ohio. Very reasonable on prices. Usually contractor prices. Talk to Rick. He know to ask the right questions should there be some clarification needed.
1-888-814-1110.
I've been buying parts from them for years w/o any problems.
Jun 23, 2009 | Freezers
ICE BUT NO CUBES
look inside ice bin to see if auger wheel is broke,sometimes the plastic wheel cut and break,hope this helps-mike
May 25, 2008 | Avanti Freezer Compact Ice Maker - 12 lbs....
Leak inside my whirlpool fridge
I have the same problem with my Whirlpool Refrigerator. Sounds as though the unit is not going through it's defrost cycle properly.
I have narrowed it down to 2 things.
1) The Defrost Timer is bad and may need replacement.
2) The Defrost bar (located underneath the cooling coils in the freezer unit) is bad and may need replacement.
I would check to see if your timer is even running. You can tell by first locating it (could prove to be the hardest part) and look at the little winow on the front. You will see that the internal wheel is moving if it is operational.
Next remove the panels in the freezer unit and see if the drian hole is plugged with ice. That is what I found upon checking this.
I believe what was happening was that the coils would drip and freeze up over a breif period of time. Layer after layer would build up, plug the drain hole and any liquid would find the path of least resistance and flow with gravity. In this case, directly into the refrigerator section.
If this scenario is present, the heater bar may be bad. I only know one way to test that theory.
May 22, 2008 | Freezers
True 31 cu. ft. / 878 liter Upright Freezer TR1F-1S Logo
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
