I have a 15 year old York 80 diamnond unit and i have four flashes which tells me to open up limit? how do i do that? thanks.
    Genius:
  • 1,033 Answers
A limit switch opens when the heat exchanger gets too hot. To check the switch with a meter turn the power to the furnace off, then disconnect the wires from the switch and set a meter to resistance, if the switch is open the meter will indicate infinite resisitance. There are several reasons why a limit switch opens and some of those reasons are
1) dirty air filter
2) the gas pressure on the gas valve is set too high
3) a problem with the blower motor
Posted on Jan 03, 2011
York diamond 80 furnace
Each step in the process must be satisfied in order to go to the next one. Yes, make sure the "Hot Surface Igniter" is good. Is the venter motor reaching full speed to close the air switch? Did you check the end of the vent pipe that nothing is obstructing it - like a bird.
Apr 01, 2017 | Heating & Cooling
Four flashes open high limit explain
Blower is probably bad. Dirty filter or not enough air flow
Nov 17, 2012 | Emerson Furnace Control Board Lh33wp001...
My central AC is a York Diamond 80 (also my furnace). Thermostat set on Cool, isn't cooling. and when i shut thermostat off, it continues to blow air. red light flashing inside unit code = Limit switch...
One of the limit switch in the furnace is tripped or went bad....
Try to find all of the reset switches and push the little red button on the top to reset them...
If that don't work you will need to take an electric meter and test each switch to see which one is bad...
heatman101
Aug 23, 2010 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
GMN FLASHES 4 TIMES
The four flashes means limit switch is open or there was a flame roll out. Is the unit very old? If not make sure all vents in house are open and not blocked to let the heat move out of the ducts. Maybe one limit switch is getting weak. They don't go out very often but trying to eliminate problems to narrow it down. ken
Jan 31, 2010 | Goodman Heating & Cooling
I HAVE A YORK STELLAR PLUS,MODEL PEUDD12N09501C 15 YEARS OLD. THE AIR INDUCTION MOTOR RUNS FOREVER. THE AIR INDUCTION MOTOR COMES ON , THE THE THERMOSTAT CALLS FOR GAS, THE IGNITOR LIGHTS THE GAS, FURNACE...
Check the filters first, then check for blockage in the return or supplies. An easy way to do this is by putting your hand in front of the vents to make sure accurate airflow is there. Your furnace has limit switches on it that detect heat, and if heat is getting trapped inside the unit to much, you will trip these switches and the blower will just run forever. Then you have to reset it or wait forever. But try those few things first. Hope this helps.
Nov 26, 2009 | York Yankees Bedding MLB Comforter
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
York Dianond 80 Furnace
You have a limit switch that needs to be reset. It is probably the roll out switch that is located on the burner housing. The limit switch is a disk about the size of a dime or penny and has two wires to it. There is a small button in the middle of these two wires. Press this button firmly to reset it. Look for all the limits that may be on the unit that is manual reset like the one described above and do the same. This should correct your problem.
Apr 12, 2009 | Water Heaters
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
