Question about Panasonic PT-52LCX66 Projection Television
I am changing bulb # TY-LA1001-K on a panasonic dlp tv mod.# PT-52LCX66-K . bulb is easy to change but lens in housing is burnt . can it be removed from housing & cleaned with anything ?.
    Brigadier General:
  • 8,909 Answers
Very carefully remove the lens, ensuring you put it back in exactly the same place and way around!
Clean it with isopropol alcohol and a tooth brush, let it soak if needed.
BE CAREFUL!!!
Re fit it as that forms part of the heat shield.
Posted on Jan 03, 2011
How to remove yellow in center of screen on panasonic pt-52lcx66-k hdtv
You might start by cleaning the lenses & mirror(this may use a Mylar sheet rather than mirror,don't try to clean the mylar) then install a new lamp
part#: TY-LA1001 $70.00 http://www.tvpartsguy.com/servlet/the-11855/TV-Lamp-TY-dsh-LA1001-for/Detail
or $49.00 to $80.00 http://www.shopjimmy.com/catalogsearch/result/?q=ty-la1001
If that doesn't cure it you most likely need a new light engine/optic block which would make the repairs cost prohibitive even if you can locate the light engine.
May 15, 2014 | Televison & Video
How to remove yellow color in center of tv screen on pt-52lcx66-k panasonic hdtv
May 15, 2014 | Panasonic PT-47WX53 47" Rear Projection...
How do I replace the lamp and housing unit on my panasonic PT-52LCX66
You need a TY-LA1001 lamp assembly. Our Panasonic TV Lamp and Bulb Installation Guide shows how to change the lamp and has links to Panasonic Users Manuals.
easyab@hotmail.com
Feb 11, 2011 | Panasonic PT-52LCX66 Projection Television
Gren light of power is flashing but not powering up
Have you replaced the lamp it sounds like a bad lamp issue this lamps are good for 2-3 years of use the first thing I would do is replace the lamp is should solve your issue here is the lamp you need
http://cgi.ebay.com/PANASONIC-TY-LA1001-TV-LAMP-REPLACEMENT-BULB-TYLA1001-/320581342030?pt=LH_DefaultDomain_0&hash=item4aa423134e
Sep 21, 2010 | Panasonic PT-52LCX66 Projection Television
TV does not start and lamp light flashes red
Your lamp has gone out. here is a replacement for it,
http://lamps-dlp.com/ProductDetail.asp?PartNumber=TY-LA1001&A=G&B=LA1001
i would pick the more expensive one as it is from Panasonic and will have way more life then the cheap Phillips replacement.
Replacing the lamp is easy. Here are instructions.
http://www.fixyourdlp.com/manuals/Panasonic/TYLA1001.pdf
Aug 27, 2010 | Panasonic PT-52LCX66 Projection Television
Where do i locate lamp in my panasonic pt 52lcx66 t.v.?
The left speaker grill comes off then the lamp door will be behind there. Mind you if the lamp in your TV still works and you are changing it. Make sure that you let the TV cool down for a minimum of an hour before handling the old lamp. Also your lamp part number is TY-LA1001. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Panasonic PT-52LCX66 Projection Television
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Lamp is blown off
The PT52LCX66 Comes with a one year factory warranty. In most cases the bulb is a normal wear and tear item and would not be covered. (Kind of like the batteries in the remote). I can tell you if you are past a year you will have to buy a bulb and there are some good prices on-line. Approx $100-$300 for the bulb which usally lasts on average about 3-5 years. If you are still with in the one year factory warranty, you can call panasonic and give a good arguement. (Not if in a commercial setting)
Please rate my answer and let me know on what other questions you may have on this topic. Tech Malick
Feb 23, 2009 | Panasonic PT-52LCX66 Projection Television
PT-52LCX66-K picture is darker than normal...
Sounds like you need to replace your lamp. The lamp number for this panasonic TV is TY-LA1001. Lamps run anywhere from $120-$250.
Nov 12, 2008 | Panasonic PT-52LCX66 Projection Television
Need bulb
Post your model number and I will post a link where you can get one at.
Apr 26, 2008 | Televison & Video
Panasonic PT-52LCX66 Projection Television Logo
198 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
