Question about HP LaserJet 3390 All-in-One Multifunction Printer
When I print a batch, why are the sides of the paper dirty as if picking up too much ink?
  • 147 Answers
You have a bad toner cartridge. Recycled ones are typical of this problem. Change it and clean any black toner from inside the printer (after cart is removed) install you new cartridge and away you go.
Posted on Jan 03, 2011
That when i print there is doted ink on the paper
Did you check the print head nozzles? every brand has it own way to check the print heads. So yours should have one to.
Sometimes you also need to remove dust, picked up by the print head, but don't try to use tools for that or remove anything from the printer. Just feed some thicker sheets of paper through, without printing.
Mar 15, 2015 | Office Equipment & Supplies
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ink there. My printer does not pick up the paper fron the tray. It only picks it up when I use thick paper and I help it with pushing it into the machine. Always the smart panel telling me there is a paper...
The pick-up roller at the rear of the printer probably needs to be cleaned using an alcohol solution as over time it picks up dirt and ink from the paper being fed through the printer, especially if printing on both side by turning the sheets over.
Oct 27, 2011 | Samsung CLP 300 Laser Printer
My brother gave me hos psc 1315 he had.The printer wasn't workin 1 year and i tried now to work and it doesn't print! The black ink is new (it prints 1 time when it wants not so clearly and then...
the printing cartridge are probably dry out. you can try to take them out and touch bottom side with soft paper to see if any ink will leak out. you can try to shake them rapidly while holding in hand, keeping the paper on the bottom side (because if theres ink you will get dirty :)
Sep 18, 2011 | HP PSC 1315 All-In-One InkJet Printer
My epson 710 artisan gives an error message that there is a paper jam or is out of paper, when I try to print a photo, it feeds through 2 blank 4*6 photo papers. There is NO paper jam when I check it, and...
Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
Jul 24, 2017 | Epson Artisan 710 AllInOne InkJet Printer
Paper doesn't get pulled in when trying to print. only right side goes in a little bit and then get message that there is no paper
Most likley a dirty pick up roller Remove the paper and with a damp cloth, clean the main pick roller with a side to side motion. Also check on the left side for debris that could be impeding the paper path (previous jam torn out incomplete)
Jan 03, 2011 | Office Equipment & Supplies
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Not printing properly
if its printing junk prints please reinstall the printer driver and check
if its printer unclear print please replace the ink and check
Dec 28, 2009 | HP DeskJet 1120cse InkJet Printer
Epson Stylus R220 CD Print Smears after printing.
It has to be a bad batch or the wrong system.
Are you sure that the disks are labeled inkjet printable and not lightscribe?
Most printables are white in color and lightscribes are tannish.
Jun 18, 2009 | Epson Stylus Photo R220 InkJet Printer
I have a lexmark E120, great little printer just went to print and it was down to one sheet of paper, I got a batch of papers to feed in, as I was printing a large doc, and in a split second it started...
In the back of printer you have door. Open it and there you can clear jam. Remove paper but slowly and easy. Close door and it will work fine.
Good luck.
Sep 15, 2008 | Lexmark Office Equipment & Supplies
HP LaserJet 3390 All-in-One Multifunction Printer Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
