Question about Whirlpool AWG5122 Front Load Washer
My machine will not spin dry and empty the water after a wash, the lights will just blink and the machine will stop.
My machine won't spin or drain and just goes on and on for hours not taking notice of the cycle I put it on, can anyone help?
Posted on Sep 29, 2011
5 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: Roper Wash Machine Model # RAS8333RQ4
check the switch under the door , it could be damaged , check with a multimeter at OHMS setting , if there any reading then switch is OK , if not try to clean it up with tuner cleaner , you can purchased at RADIO SHACK.
Posted on Dec 17, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: AL5143VW! doesn't empty water on any setting - any ideas?
Replace the water pump located on the bottom of the unit. You can order the part on repairclinic.com
Posted on Feb 20, 2009
SOURCE: over load washing now wont spin
stops between wash
Posted on Apr 29, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Thre washing machine is stopping on rince, the light is flashing. we press start again and it goes through the same routine till it hit rinces and stops. the clothes are still full of water, we have to move the dial to rince and freshen up to finish the wash. any ideas..?
Posted on Jun 16, 2011
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
A1400WD has not emptied and has flashing lights and on/off flashing rapidly. The machine was set on a hot wash for cleaning. Water left in the machine up to the bottom of the door and I cannot open the...
Get some buckets
Take the drain hose off the back of the machine, undo any clips so that it lays it down flat
Put the end into a bucket and the machine will drain off.
When water has stopped running switch off the machine leave it for a few minutes and then put it into a spin cycle
Leave the hose in an empty bucket
That will dry the clothes and relaese the dorr
Your next problem is getting the obstruction out of the drain pump
For that you need a man that can
Oct 20, 2009 | Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool AWG5122 Front Load Washer Logo
310 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
