Question about Dishwashers
Hi :) We have a Bosch slimline dishwasher type SRS56A02 GB/08 - it doesn't draw in water - the timer counts down but nothing happens. We checked these pages and cleaned the filters on the inlet water line but no change :( I saw that it might be the inlet water valve - is this easy to get to - do we need to take off panels? if so, is there a manual available please? Over the past week or so it had got noiser - it was at its quietest while the water was draining out of the machine.
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
  • 161 Answers
SOURCE: Bosch Slimline Classixx,water cutting on/off
Does it still have enough water to wash? Mine does this too. The float is very sensitive. If it gets the dishes clean don't worry about it.
Posted on Jul 03, 2008
SOURCE: Bosch SHU9925UC Dishwasher Stuck in Initial Drain Cycle
OK Bosch Dw fans.........here is the fix if your SHX dishwasher is stuck on the drain cycle. This may save you a couple hundred bucks.......so listen up. There is a tendency for the very small float switch to STICK in the ON position, which will cause the drain motor to continuously run......and DISallow any other function to work. DISCONNECT POWER. Did I mention to disconnect power? Take off the front base cover....2 torx screws. Remove the other 2 torx screws in the metal clips that fasten the top of the DW to the underside of your countertop. NOW...carefull slide your DW out. You may have to disconnect your water and elec supply if you do not have enough slack to pull it out. Once the DW is out of the cabinet, remove the shiny metal cover on the LEFT side by removing a single torx screw. You will now see a small plastic assembly with a red plastic piece that moves up and down as it rides on a small red styrofoam float. This up and down movement engages a small white plastic switch visible with 3 wires coming out of it. You can carefully UNSNAP this switch out of its mount, and pull the 3 wire plug off of it. THere is a small square blue plastic tab that is supposed to easily slide in and out of the switch. If it is stuck IN, you can sometimes tap the switch and the blue tab will pop out, which is what it is supposed to do without tapping it. You can carefully with a knife blade separate the case on this switch and note the way it comes apart. Clean out any micro debris out of the small channels that the blue tab ride up and down in. Then set it in the channel while holding up the small switch tab that rides on it and see if it slides up and down without sticking! I like to take a piece of wax paper and rub in on the channel and blue tap to provide some lube for the switch to slide easily on. Now, put the switch back on and manually move the red plastic assembly up and down while you are watching the blue tab. The tab should ride up and down with the red assy. If not, buy a new switch. Google the # on the switch and order one. If the tab slides up and down, put things together in reverse order and give it a try. Hope it works for you. This should take you an hour give or take. Take the $200 you just saved and have a night out on me. ........so even though these German Appliances have a good name because of past reliability, the american tendency to value engineer them with plastic parts to reduce costs and increase profit.........just cost you an hour of your time. Will we ever learn.? ......if it ain't broke, value engineer it until it only lasts through the warranty period so you can then collect service and parts blood money from your fellow american.
Posted on Jan 11, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
Bosch washing machine starts filling with water, then does nothing, timer counts down but no movment
have a technician check it out as it may be a board problem
normally the fill level switch ,when the set water level is reached activates 2 things
it stops the water in and at the same time moves the program on to start the wash cycle
so it is either that switch or the program board
Aug 13, 2015 | Bosch Washing Machines
Electric smell bosch dishwasher
Do not use this appliance until you have check if it is one of the bosch dishwashers subject to a recall repair. Use the link below to check
http://www.repairaction.co.uk/bosch
Apr 16, 2013 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Mar 04, 2012 | Dishwashers
Bosch Integra SHU 9955US/12 - when we start wash cycle, the detergent dispenses and the tub fills with water, but the wash cycle never starts (never spins spray bars). Seems like timer is counting down,...
Sounds like your motor is burned out. The drain motor and wash motor are seperate on your machine. You can check for power going to the motor, but to do this you might have to pull the dishwasher out. While the cycle is running check for 120 VAC going into the motor. If you are getting power and nothing is happening, you will need to replace the motor, otherwise you will need to replace the motor control board located at the base of the machine.
Jan 31, 2011 | Bosch SHU9955UC Built-in Dishwasher
Water leaking from the bottom of the dishwasher.
ck the float it may be comming under the door . if water is still in tank after cycle / clean the screen in the bottom it is a lift out basket . ck for resstriction in drain line . all of thes will cause over fill and flooding . your model may have a pressure sw . sometimes food gets in the air line / remove tube and blow out .. mm
Dec 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher wont start
check that following -
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
good luck.....
Mar 28, 2009 | Bosch Dishwashers
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Owen Barnes
