Question about Panasonic CT-27SL14 27" TV
Tuner appears to be stuck in channel 4. Cannot change Channel.
  • Panasonic Master
  • 6,771 Answers
It is a tuner selector problem, either the processor controller ic is the problem, or the selector ic. The easiest solution use a VCR as your channel changer, and check to make the VCR is set to channel 4.
Posted on Jan 03, 2011
Testimonial: "The solution is great!! Thank you!"
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Element Plasma image overlayed with ghosting
if the images of the previous channel what you are looking it is the pdp panel problem plasma display -pdp panel
Nov 05, 2013 | Element Electronics PLX4202B 42 in. Plasma...
ILO 26HD television flat screen won't change channels/stuck on 11
Try doing a channel scan or autoprogram of the tuner again. This should fix the issue.
Nov 11, 2009 | Televison & Video
TV stuck on Channel Fixed;6
Go in to the user menu and find where the Auto Channel Setup is located. You can consult the instruction booklet for your TV set. Try this and see if it works. If it does not then there are a number of areas in the set where there can be some defective components.
The tuner is controled by the uPC system. There are a number of interface circuits involved for the channel control. Problems in these areas can cause the channels to not be able to be changed.
Jerry G.
Oct 19, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Can not change TV channel on DVD Recorder.
some dvd/vhs tuners do have this locked issue and since poor qc or qa on the manuf. part , they think since items are low cost anyways buy another one.
Mar 27, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Trying to watch vcr on channel 4, but the vcr is set to channel 3
You can watch the TV programs
with the tuner of the unit. (Usually
channel 3 or 4 of the TV is
available for the RF converter
setting.) Be sure to connect the
unit to a TV using the RF cable.
Select channel 3 on your TV.
Press [VIDEO/TV] on the remote
control.
• If noise appears, change the
RF output channel of the unit to
CH 4 by pressing [VIDEO/TV]
for 3 seconds. The RF output
channel will alternate between
CH3 and CH4
Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
Magnavox TV
It's possible that V-chip is locked.. Go to the menu and see if the lock option is active... The backdoor password is 0-7-1-1 twice.. Entering it the first time, if it times out, will display "incorrect" just enter it again and it should ask you for a new password..
If that's not it let me know and we'll try a couple other things.
Bill
premtech@willapabay.org
Nov 17, 2007 | Philips Magnavox MS3652S 36" TV
Television stays on one channel
You likely have bad solder connections in the tuner.
Jul 12, 2007 | Sony KV-35V75 35" TV
Channel gets stuck
I had the same problem on my TY tuner. The connection on the circuit board is bad. Has worked it's way loose. If your good with a soldiering iron you can fix it.
Jun 21, 2007 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Panasonic CT-27SL14 27" TV Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
