Question about Acer AL1916W 19" LCD Monitor
Desktop seem to be out of alinement and some of the applications are off the screen
  • 327 Answers
Sometimes it depends on your operating system (OS). for instance i have a LG L226WTQ and when I'm working with windows 7 this problem appears for me too but with windows XP not.
installing or using bad applications (harmful or incompatible) also can be the cause.
mostly video card (VGA) is the cause.
you should check your motherboard model and your VGA.
maybe they are incompatible each other.
Posted on Jan 07, 2011
What does PPI stand for in the System Security settings?
PPI usually stands for Pixels per Inch. It's a method they use to measure resolution. Increasing this would make things seem smaller on your screen. It could also cause problems if you set it too low by making the windows and applications seem too big for the screen.
Mar 11, 2015 | IBM NetVista 8305 PC Desktop
Device Error 373 Reset
Hello afterhours!!!
Is seems funny but according to blackberry customers , seems the error is fixed by dropping down the phone on a floor!!!
Not sure about the solution .. But y not give a try on a carpet floor!!
Regards
Smilemaker
Jun 17, 2008 | RIM BlackBerry 7290
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
HOW DO I AD AN APP TO MY START SCREEN?
If its windows operating systems, please follow the below steps
1.To add an application to the start screen - > drag and drop the application icon to the start it will be visible
2.To add application to the desktop screen - > right click the application icon ->select send to ->choose desktop (create shortcut)
If it didn`t solve your query, let me know with your operating system info and the issue.
Thanks
Oct 20, 2013 | Computers & Internet
How do I make the page to cover the whole screen?
Cut a larger sheet of paper. Just kidding!
What 'page'. Do you mean Windows desktop? Or an application within Windows?
If the desktop is not filling the screen, the monitor should have an 'auto' setting within its menus.
My Samsung monitor (different model) has both a menu button and an auto button.
If you are referring to an application window (you can see some of the desktop around the outside of your application, just maximise your application.
May 16, 2010 | Samsung SyncMaster 2253LW Monitor
How to install an application for my blacberry cellphone
If you would liketoinstall application using the application loader tool in the Blackberry Desktop Manager.
You should verify that the application to be installed on the BlackBerry smartphone is saved to the computer before completing the following steps.
If you are using BlackBerry Desktop Manager version 4.5 to 5.0 then you need to follow this steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. In BlackBerry Desktop Manager, click Application Loader.
  3. Click Start where it says Add / Remove Applications.
  4. Type your password, if prompted, and click OK.
  5. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
  7. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
If you are using BlackBerry Desktop Manager version 4.0 to 4.3then you need to follow this steps:
  2. In BlackBerry Desktop Manager, open the application loader tool.
  3. In the Application Loader Wizard, click Next.
  4. Type your password, if prompted, and click Next.
  5. In the Handheld Application Selection screen, click Add. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Handheld Application Selection list, verify it is selected, and click Next.
  8. Once the application is installed on the BlackBerry smartphone, click Close in the Application Loader Wizard.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Screen switches from application back to desktop
Open your System Preferences. Go to Dashboard & Expose. This is a very helpful application in my world. Whenever you want to see all the windows, hide windows, start screen saver, you just push your mouse into the appropriate corner. Sounds like you have a corner set and when you hit it, you trip the effect. Change the corner and check them out, Handy to use when you have multiple windows open. Experiment and see.
Jan 05, 2009 | Apple Power Mac G5 Desktop
Palm TX: Digitizer problems - can't use all functions; i.e.all those on bottom row of screen. Soft reset and touch-screen alinement exercise doesn't seem to work.
I developed the same problem after owning my TX for about a year and a half. I found an acceptable solution by experimenting with the digitizer. Instead of tapping the very center of the bullseye, I tapped off center until I found an acceptable setting where accessing functions anywhere on the screen would work for me.
Nov 14, 2008 | Palm TX Handheld
Acer AL1916W 19" LCD Monitor Logo
163 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
