Question about Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm)
I have a 4/12/52 rifle scope and I need one cap that Ilost
3 Suggested Answers
SOURCE: tasco scope
Sight in rifle.Put top(elevation)cap back on with the"0" facing back.Be careful not to make it "click"as this will change point of impact.The way this works is you aim at animal and adjust the power(3-9)until the animal's body is between the 2 lines.Look in the little window on eyepiece to see distance of selected animal.Then click top knob to the correct distance(200,300,etc.)This should raise bullet impact for that distance.I've had this scope on a .270 since 1980 and never used this feature.(I only bought it because the scope was on sale)
Posted on Feb 06, 2011
SOURCE: I have a tasco 3x9x50 world class rifle scope. The
Try some PB Blaster. Wet a q tip and apply to the area at the base of the turret caps. Wait a few minutes and reapply. Then using a small pair of vice grips attempt to twist the turret covers off. A cotton cloth will help keep the gripping surfaces of the pliers from scratching too bad. Hope this helps.
Posted on Aug 29, 2012
Sold by Walmart. I need caps for the 3X9-40 scope that comes with that rifle. What brand of scope is it, or what caps will fit ?
The "40" is 40mm....that's the front lens diameter. It's a standard size. the rear is pretty much all the same so just look on Ebay for a set of caps for a 40mm scope. It's a *really common size*. You won't have any probs finding it. If you get an elastic type, you might need to adjust the elastic length, but that's no biggy.
Dec 30, 2015 | Mossberg 4x4 270 Win 24 Synthetic Matte...
Where can I get replacement caps for the elevation adjustments.
the only way to find cheap caps it try a fuw gun shops to see it they have any old scope that dont work and buy the caps that will fit your scope most gun shops keep old broken scopes just for that?
Nov 27, 2010 | Burris 3-9x50mm Fullfield II Rifle Scope...
1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Oct 09, 2010 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
I have the 6x18x65LU atn rifle scope. I had the scope mounted to my 30-06 on two 1" weaver rails. the scope keeps sliding forward though the adjustable scope rings. I've been recentering the scope and...
be cearfull you dont crush the scope tube,,but try rapping a little strip of sticky rubber or plastic tape round the scope tube then nipping the scope ring caps down onto this,,,but i think your scope rings are worn out or the wrong size,,ie 30mm not 25mm
i have air rifle scope's on my 7.62/308 and on my 303 none of them move about at all and they have stayed on zero for years now!
Aug 25, 2010 | ATN 6-18X65LU Daytime Rifle Scope
Cross hairs canting to the left..how do i recenter the recticle?
From your short description, it sounds like the Horozontal (the ELEVATION) reticle is canted to the left. If that IS the case then do this;
Sand bag the rifle on what you know is a level and firm surface. The rifle MUST be level itself. You can use a small level to determine this.
Without moving the rifle, look through the scope and determine if indeed the horozontal or ELEVATION reticle is indeed canted. The reticle should be LEVEL in relation to the ground and the rifle itself.
If it still appears to be canted, loosen the set screws of the scope ring caps (Not the scope mounts) and while looking through the scope, gently rotate the barrel of the scope clock wise until the Horozontal reticle appears to be now level. Re-tighten the scope ring caps and look through the scope again to make sure the Reticle is still 'level'.
You must now make sure that your scope is still 'zero'd'.
IF the issue is something other than what I have assumed from your description, please send me a msg. with more detail and I will be able to resolve whatever issue you are having. Include the 'Brand and model', plus the power of it, and the brand/model/cal. of the rifle the scope is mounted on.
Good luck. :)
Apr 27, 2009 | Nikon Tactical Rifle Scope 4-16X 50...
Cap cover pentax 3x-9x scopes
You do not define "cap cover" as to whether it is a 'lens cap' of which the Objective Lens comes in varying sizes with the 3x9 scope depending on the model.
However, you should be able to find one in the size you need at most any Firearms supply store. I have even found a lens cap for a Leupold at a Walmart.
Barring that, go to; www.pentaxsportoptics.com, they should be able to help you in your quest.
Good luck. :)
Apr 14, 2009 | Pentax 3X - 9X 40mm Lightseeker XL Glossy...
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
I need a scope guide instruction sheet for the Tasco 28a
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright.
2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim.
3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading.
4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result.
5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline.
6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line.
7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle.
WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY
At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments.
8. Restore the stud tension by pressing the end of the spring.
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Just bought used 8x32 swat not sure how to use it. are the win and elev numbers for shooting or just for siteing in rifle
They are for sighting in the rifle only.I know on TV the shooter reaches up and turns a knob.BOGUS! after sighting in the rifle, always replace the little caps because the scope is not sealed unless the caps are on.without the caps, moisture can penetrate the scope and fog the lenses.Good Luck
Dec 08, 2008 | Barska Optics Barska 10-40x50 Ir Swat...
PARTS FOR A TASCO RIFLE SCOPE
Hi, I think they can be found on amazon. here: Amazon com tasco rifle scope parts I hope this was helpful. cheers
Dec 07, 2008 | Tasco ® Silver Antler® 3-9x40 mm Scope...
Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) Logo
41 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
