Question about Century Tool 2320I Heater
Century RMC-FA50C propane heater Where are parts available? Ie: Spark Module.
3 Suggested Answers
SOURCE: Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Posted on Jan 17, 2009
  • 7 Answers
SOURCE: Where do I go to find replacement parts for my
To find replacement parts for your Dyna-Glo heater, go to the GHP Group Inc, website listing the heater manuals and locate the appropriate manual for your heater model and select it.
After you've selected the appropriate manual (which appears to be this one from your model description), then you can either download it to your computer or print it out. Inside the manual you'll find exploded views, parts lists, troubleshooting, and instructions.
When you locate the items you need to replace, contact your local authorized service center for the replacements (it might be quicker to pick them up than having them shipped to you from the manufacturer). If you don't have an authorized service center near you, you may call the company directly at: (877) 447-4768.
Hopefully, you'll have your heater up and working again in no time.
Posted on Jan 13, 2011
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
Need a control knob for : dyna-glo pro propane heater. model # rmc-tt 30dgp-01, # rmc-tt30dg, #rmc-tt30gd. serial: # 09 005720
Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Dec 17, 2010 | Garden
I have a Dyna-Glo RMC-50LPT propane heater that is about 5 years old and I can't get rid of the yellow flames when it operates. I have tried: - removing the heater and blowing everything out with a...
Dennis easy fix what is your out going gas you will need a manometer to verify it accurately or adjust your gas valve til your blue flames are gone. Let me know what you find!
Dec 16, 2010 | Heating & Cooling
Had heater sitting in garage for 2 years and now it wont fire-up. i can smell propane and theres pressure when i take off tank. whats wrong? oh yeah i have spark to.
Alway clean the unit first before starting cause little critter could block fuel flowand spew out instead of where it suppose to go!
Dec 17, 2009 | Dyna-Glo RMC-8001SS Heater
Where do I go to find replacement parts for my Dyna Glo propane heater? I have model # RMC-FA 50A,50 I think I might need a new spark module as the fan works but it will not spark. (I have the continuous...
Dec 12, 2009 | Dyna-Glo Heating & Cooling
How long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
Jan 18, 2009 | Dyna-Glo RMC-8001SS Heater
Jan 11, 2009 | Century Tool 2320I Heater
I have no manual and no clue
After not finding any help on the Internet, I went to Home Depot to see if they could help. I deduced through my own that the ignitor has failed. (symptom: Turn on the heater, no buzzing, no ignition, heater turns off, light blinks). It's the nifty little black box that has two white wired leading to the circuit board, and two thick black wires going to the spark plug. Of course, Home Depot doesn't carry parts.
They had one Dyna Pro heater on the shelf. My wife found a phone number on the box. We called it and sure enough, we found the company and was able to order the replacement ignitor over the phone. Total cost: $33.00 (Including shipping).
IS HELP OUT THERE. Here's the info:
GHP Group.
7500 Saint Louis, Skokie, IL 60076
1-877-447-4768
The replacement part is part number: 39E0002500
It fits models: RMC-KFA125TDGP, RMC-KFA170TDGP, and RMC-KFA70TDGP
Hope this helps.
Nov 20, 2007 | Heating & Cooling
Century Tool 2320I Heater Logo
347 people viewed this question
Top Century Tool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Century Tool Heating and Cooling Expert? Answer questions, earn points and help others
