Question about Sonic Impact Technologies IF22 Docking Station for Apple iPod (648027050846)
I need a replacement rechargeable lithium ion battery,2000mAh, GB/T 18287-2000. nominal voltage;7.0v, max.charging;8.4v. searched internet. notjing looks like the one already in the player. please help!
These battries are usually used in hand held devices such as mobile phone and PDAs, If you are not able to get these battries you may buy 3.5 Volt battery which are available at Mobile stores and can be joint together by joint them in series by soldering. Thus you will have battery with 7 volts output.
Posted on Feb 08, 2011
  • Jim Harvey
    Jim Harvey May 07, 2014
    I have one of those. Based on measuring the battery pack, it looks like there is a pair of common 18650 cells inside. A battery dealer should be able to open the pack and replace the cells.
Went to use it and it won't come on. Thought battery might be dead and plugged it in and it still won't come on.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Mar 11, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
My pendo wont fully charge, and now it won't come on at all
Feb 23, 2015 | Tablets & eReaders
My tablet will not power on & shows no signs of charging
Feb 22, 2015 | Tablets & eReaders
My kindle of two years old battery will only charge to half full, is that normal and can I replace the battery
Places like Batteries + are able to replace some tablet batteries.
Jan 20, 2015 | Amazon Kindle Fire HD
Kobo not accepting a charge
Jul 28, 2014 | Kobo Arc
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
Jun 07, 2014 | Tablets & eReaders
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
used up.
Jun 05, 2014 | Tablets & eReaders
Why does my light not charging
Lithium ION batteries are ususally rechargeable. The use mode for these batteries is that there
used up.
Jun 05, 2014 | American DJ megapixel led high powered led...
Hello, I have a VZ-702M Lithium-Ion battery kit
Friend Dean,
A quick anonymous search of all the Web via the search terms [ buy VZ-702M battery] and the mighty mighty http://ixquick.com Privacy-Enforcing Meta-Search Engine from Heaven reveals on the first pass that URL
http://www.amazon.com/VariZoom-VZ-702M-Rechargeable-Lithium-Ion-Mounting/dp/B0010CDOV4
provides the item you seek @ $35.90 USD - with free shipping included - at least to US customers. Three in stock at lookup-time fwiw. YMMV re Amazon service due to your own location, of course - but I for one do tend to think Ixquick will doubtless prove productive for you too if so.
Good luck! (FINE monitor, btw.) And that is all. 0{;-)o[
Aug 16, 2013 | Vacuums
Zen shuts off after only playing a few songs
How long have you been doing this for (months)? You may have already drastically reduced the life of your battery
Battery
& Charging
The Zen’s battery:
The Zen uses a 3.7v rated Lithium-Ion rechargeable battery. A 3.7v rated Lithium-ion battery actually gets charged to around 4.2v with a tolerance of +/- .05v. A charge of 3.7v/3.8v is actually about a 50% SoC. At 3.3v, lithium-ion batteries have typically only utilized 70% of its 100% charge capacity.
Charging Voltage = 4.2v (4.1v)
Nominal Open-Circuit Voltage = 3.7v (3.6v)
A note on Over-Discharging and Over-Charging:
In general, Lithium-Ion batteries do not like to be overcharged (usually above 4.2v) or excessively discharged (under 2.5v-3.0v). If a Lith-ion battery falls below 1.5v, then typically you shouldn't try to recharge it at all for "safety" concerns. A fully discharged lithium-ion battery causes the formation of copper shunt in the cell which begins to get extremely hot when attempting to recharge. A lithium-ion battery should not be charged above 4.3 volts. Above 4.3 volts and the cell causes lithium metal plating on the anode. The cathode material becomes an oxidizing agent and loses stability and begins releases oxygen. This can cause the battery to heat up. Lithium-ion cells should never get above 130°C (265°F). At 150°C (302°F) the cell becomes thermally unstable and can eventually lead to a thermal runaway. These are the safety reasons why the low and high voltage cut-off and temperature sensing circuits are used. If the internal temperature of the battery gets to high, the temperature sensing circuit can initiate a mechanical pressure switch that will permanently cut-off the current path and prevent anymore charging.
How do you charge the Zen (Battery)?
It can be charged by connecting it to a USB port on a computer or by using an AC Wall Charger within the Zen's charging specs (see below).
Can I use my cell phone's AC Charger to charge my Zen?
I believe the max input voltage of the Zen is around 5v. Most devices that can charge or run off the USB host power can handle the max 5v of USB ports. 4.2 volts is usually the max Lithium ion batteries are charged to. It is usually around when the high voltage circuit is triggered and stops the charging of the battery. I would not connect a charger to the Zen that puts out more volts then 5v with an output current beyond 2400mA (2.4A) to be safe.
When and how often to charge?
To be safe, I would avoid frequent full discharges because this puts additional strain on the battery and usually shortens its life. Partial discharges with frequent recharges are better than one deep one. Recharging a partially charged lithium-ion does not cause harm because there is no "memory effect" like with older type Ni-Cd (nickel-cadmium) batteries.
Do I need to charge the Zen for hours before I use it for the first time?
With Lith-Ion batteries, the first charge isn't any different then any other charge. There is no technical need to fully charge it the first time you get it other then the fact of being able to use it longer since it will have a full charge. They are not like other types of previously used rechargeable batteries that needed the full charge at first. Most likely by the time you get everything all figured out and loaded onto the device, the battery would be fully charged anyway.
Please note: I do recommend that you at least connect the Zen to a computer while it has sufficient charge on the battery in order to properly be detected and have its devices drivers load properly. In other words, don't use your new Zen for a period of time to where you drain enough power from the battery to just come on and turn off automatically or to the point the Zen doesn't come on at all. If you do, then you may have detection and charging issues when you go to connect the Zen to the computer.
How long will the battery in the Zen last?
Lithium-Ion batteries have a life span of about 300-500 discharge/charge cycles or 2-3 years from being manufactured.
Storing or not using the Zen for long periods of time:
Lithium-ion batteries (by themselves) with no built-in voltage monitoring circuit have a really low self-discharge rate (1-2% a month) when not being used. Having the addition of voltage monitoring circuits will slightly increase the discharge rate, but should not reach the point of excessively discharging the battery to where it won't turn back on unless sitting unused for an extended period of time and if its last state before powering off was a already in a low voltage state. So, as long as you aren't storing it for long periods of time at a low discharged voltage, the battery should be ok to recharge.
Accidently left the Zen plugged into the Computer all night or for a long period of time:
I wouldn’t make a habit of doing so. Long term usage like that could shorten the life of the battery. Although you may be fine for a while, leaving it plugged in occasionally all day and night, most likely won't hurt it, but leaving it plugged in every day and night may not be a good idea. Although once it is charged to 100%, the battery's internal high voltage cut-off circuit should keep the battery from over-charging and the devices charging circuit should keep applying a trickle charge when detected a drop in charge below full. However, keeping a Lithium-ion battery plugged in and fully charged keeps the battery's temperature elevated. Exposure to prolonged elevated temperatures can cause capacity loss which can then cause the battery to no longer be able to charge or hold a charge. Plus, it may be a small chance, but there is a chance that exposure to this condition for long periods could also increase the chance of a circuit failure (charging, high voltage, temperature sensing) and allow for a severe over-charge to take place to the point of thermal runaway which has been known to cause the occasional "exploding" battery, but in most cases just melt (and take some of the device with it) or catch fire.
A note regarding USB and charging:
Per the USB specs:
USB 1.1 = Minimum supply voltage is 4.4v
USB 2.0 = Minimum supply voltage is 4.75v
Both maximum supply voltages are 5.25v and a current of 500mA.
Before the USB bus interface can begin charging a device (Zen), it must return a device identifier to the hub driver (or device driver). Once the hub driver has the returned information from the device (like power requirements, supported transfer speeds, etc.), it can then begin charging the device based on those retuned values. This process is called Enumeration. Until enumeration has completed, it may not draw more than 100mA from the bus. Once enumeration has completed, it can then begin drawing up to the 500mA allowed by the USB bus.
Jun 23, 2008 | Creative Labs Zen Digital Media Player
Sonic Impact Technologies IF22 Docking Station for Apple iPod (648027050846) Logo
603 people viewed this question
Top Sonic Impact Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
jscuin6
Tom Chichester
Are you a Sonic Impact Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
