Question about Sony KP-57WS500 57" Rear Projection Television
Seeing triple images of everything - Sony KP-57WS500 57" Rear Projection Television
  • Sony Master
  • 8,457 Answers
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignmenents,have colors shadows or 3D pictures look alike?The tv convergence board have dead 2 STK Convergence ICS and some or all of it resistors too.These parts on the convergence board must be replaced to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Jan 03, 2011
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
TRIPLE IMAGE
This would be the decoder/tuner board giving out, Your going to need to take it in for a replacment of that board.
you can try to unplug it for a while and see if it resets but i doubt that will cure anything long term. Proscan is known for this issue and have been known to have bad decoders in them.
Thanks for being considerate and leaving a ratings and feedback today.
May 29, 2010 | Proscan 42LA45H 42 in. LCD TV
Image shattered/double when moving.
check your antenna connection and auto-reprogram the channels.
Apr 27, 2010 | LG 42LC2D 42 in. LCD HDTV
My projection tv is showing a triple image and i don't know how to fix it?
Go to menu then setup if you do not see convergence listed in menu then you have blow Fuse FL231. Located next to FBT flyback transfomer on right side there is 3 fuses in a roll they will look like small rectrangler caps but are Fuses.06 amp
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Triple images
It is possible you have the same problem as this person. Please remember that I am basing my answers on your info only and without even seeing the problem. Hope this helps
Mar 07, 2009 | Sony KP-51WS500 51" Rear Projection...
Seeing triple red,blue,green
you have proble with the convergences ICs if the tree colors are at fault then also check your power supply voltages the polarization resistors
Feb 08, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Triple image
You have convergence problems replace both of the STKs big black ics.
Dec 09, 2008 | Samsung HCL4715W 47" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Trouble with philps tv
First check to see if all cables and settings are correct according to the manual, if not it could be a bad board inside the set that costs $180.00 to replacce
May 18, 2008 | Philips 27PT6441 27" TV
Sony KP-57WS500 57" Rear Projection Television Logo
183 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
