Question about Hitachi 57SWX20B 57" Rear Projection Television
My tv is 8 years old and the picture is not as bright or clear as it used to be. Can the mirror be dusty?
  • Hitachi Master
  • 8,457 Answers
No,the three CRTS tubes guns coolant chemicals are not as good as before,will causes this problems. Like old dull and hallow colors pictures?Tries websites like Tvrepairwold.com,Tvrepairkits.com to buy a kit to replacemt of it coolant chemicals of one or all three CRTS tube guns.The coolant chemical kit should came with a DVD tutoring how to do it too.
Posted on Jan 03, 2011
I have a Studio 42" rear projection tv, The picture is incredibly bright, have tried to adjust the brightness but it doesn't help....can anyone help me?
I believe these were made by Samsung. You will need to search for a service manual for more specific information.
May 16, 2014 | Orion STV2763 27" TV
HCL652W picture faded will bulb replacement fix this
I would say that it is not worth replacing the bulbs. I had a similar experience with an old rear projection TV like that and I just cleaned all the dust out of it as well as I could. i cleaned the back of the screen, the mirror that the image reflects off of, and the bulbs themselves. I used a dry micro fiber cloth so as not to scratch anything. doing this might help you some, but if it is working and it is bright enough for you after a few minutes, I would just live with it until you can upgrade to a newer TV.
Aug 31, 2012 | Samsung HCL652W 65" Rear Projection...
Mitsubishi dlp tv picture is getting darker
One of two possible issues:
1. Lamp is nearing end of life and may dim just before total failure.
2. A few of these models have 2 mirrors(check with Mitsubishi to see if yours is one) A large mirror in back (never gives a problem and do not try to clean it. Some idiot in these sets used a small mirror inside that the optical unit shines the picture into (wedge shaped mirror and small) and it is facing up----the fans intake air from the front of the set around this mirror--it gets coated with lots of dust---Picture can loose up to 70% of its brightness and clarity if that mirror is dirty--looks like 20 year old set .
If you do not wish to check with Mitsubishi GOOGLE THE MODEL NUMBER with "mirrors" to see.
If it has 2 mirrors I can tell you exactly how to get at it.
SD TECH
Mar 31, 2012 | Mitsubishi WD-65736 Television
My picture isnt bright and is slightly blury, why?
It is an older set but when was the last time the 3 lens were cleaned? If a while that may be your problem.
These sets were designed to have the lens cleaned once a year--there is also a mirror but unless very dusty or a smoker not usually an issue.
Remove back cover with set unplugged---note the three large black round housings on top----clean the lens with a paper towel with glass cleaner sprayed on the towel.
This is the light source for your picture and if dusty picture will be darker and duller looking.
Let me know if questions.
Mar 14, 2012 | Hitachi 50UX57B 50" Rear Projection...
The picture seems to be getting darker. Its not as bright and sharp as it used to be. Its about 9 years old but has not been used very much. Might it need a new bulb or something? 57HX81 Proj TV Color...
simple: remove back cover and locate the three large black lens you will see top and dead center, clean them with either a lens cloth or a paper towel with glass cleaner----they are the light source for your picture and should be cleaned once a year---as they get dusty the picture gets darker and duller looking.\\
SD TECH
Apr 12, 2011 | Toshiba 57H81 57" Rear Projection...
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Nov 20, 2009 | Philips Televison & Video
Rear projection tv picture quality loss
most of these sets have 3 lens for the three picture tubes inside and also a mirror---if it has never had the lens cleaned they could be dusty and this will diminish the brightness and clarity of your picture---if real dirty the picture will look washed out------most of these sets you can remove the back cover(unplug set first) and gain access to the lens ; clean them with a lens cloth or a paper towel with glass cleaner.
Aug 16, 2009 | Televison & Video
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
Hitachi 57SWX20B 57" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
