Question about Nokia E63 C3 C6 E5 N8)
Hi, I have bought a Nokia C6-00 and it is great but for one problem: I cannot get to pair it as a Bluetooth device. Mind you, I have an N78 which worked ok with my car's Bluetooth radio but now I can't use my new cellphone while driving. Is it possible to download and install the N78 Bluetooth software onto my C6? Your help is greatly appreciated. **** Info: my C6 is running firmware version 20.2.042.248.01 Rudnei
  • rudnei_cunha Jan 05, 2011
    But how then can I make it work with my car's Bluetooth radio? Is there a way?
    Rudnei
    Hi
    Thanks, anyway...
  • 944 Answers
It is not possible to install the N78 Blue tooth software onto your C6.Because blue tooth firmware is inbuilt in the Nokia OS.So you can install N78 OS in C6
N78: Symbian OS, S60 rel. 3.2
c6: Symbian OS v9.4, Series 60 rel. 5
See the OS version varies.
You have to buy a pairable version bluetooth with c6.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 05, 2011
  • Natarajan Ramasamy
    Natarajan Ramasamy Jan 05, 2011
    There is no solution.You have to change the blue tooth which accepts C6 or the other way.
Hi, i have bought a new Nokia bluetooth headset BH503, but it is not able to pair with my mobile phone Nokia E71, apparently my phone is not able to detect the bluetooth headset.It shows " No...
Hi ttc81,
Please make sure that your phone's bluetooth is in shown to all mode and not in hidden mode.
Also check if there are any particular instructions in your bluetooth headset's manual for pairing a device.
If the above procedure does not work , try to pair the bluetooth with another mobile phone and if it gets paired , then it means that your bluetooth is not compatible with Nokia E71.
Hope this helps ...:) Let me know in case you have any queries.
Jun 18, 2011 | Audio Players & Recorders
Today I bought a Bluetooth handset a brand called Bluedio module number N65. I unable to pair this device with my Dell latitude E6410 which is running Windows 7. But its possible to pair with my Nokia E72,...
when pairing any device you must set the bluetooth activate on active devices and then in the settings select search for active devices or pair a new device
(this may vary depending on the device you are pairing)
hope this helps
Jun 04, 2011 | Computers & Internet
I have a Jabra Bluetooth headset after updating my phone with Nokia Ovi Suite I lost all my games and my paired things on bluetooth. I tried 4 times to pair the Jabra so have locked it out of my phone how...
hi, you can solve this problem in a simple method- press the power button of the bluetooth device continuously for 2 or3 s check the light of blutooth device is turned on then go to bluetooth device option on your mobile phone and select add more device the time pair the device by using this code 0000
was this helpful to you
Aug 27, 2010 | Nokia 6300 Cellular Phone
Pairing problem BH-168 with E90 nokia
Finally i solved the problem ....
So, to pair this device you need to do "Long Press" on device button until your mobile phone detect it.
That's it
Jul 17, 2009 | Nokia Bluetooth Boom Headset Headset
N 78 Bluetooth unable to search new devices
Users have encountered a lot of issues, bugs and problems with Nokia N78, the first S60 device to support Feature Pack 2. If you are facing issues with your smartphone, here are a few tips to get your mobile phone back in business. + To restore your phone to the original factory default settings, press the Menu button, then go to Tools, Settings, General, Factory settings. Here you need to enter the lock code (generally 12345). After the reset, the device may take a longer time to power on.
+ To hard reset/format Nokia N78 (all data will be lost), follow the below mentioned steps:
1. Turn off the mobile phone.
2. Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
3. While holding these three buttons, press the power button to switch on the device.
4. Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
pls reset the device fully and if no help pls update the OS dont worry it is tested 100% may be in ur case the problem solves PLS RATE ME FIXYA if u like
Mar 16, 2009 | Nokia N78 Smartphone
Pairing Nokia N78 with Motorola S805
pair using the wired headset first and that will sort
Jan 09, 2009 | Motorola Mobility S805 Wireless Headset
SHOW ME HOW TO PAIR N70 nokia phone
first go to bluetooth option then select search device then select that device then pair then enter the password 0000 or 12345 and then done
Dec 25, 2007 | Nokia N70 Cellular Phone
Bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Nokia E63 C3 C6 E5 N8) Logo
141 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
