Question about Whirlpool LSR5132PQ Top Load Washer
My washer will wash on any cycle but it will not go to the next step to spin the water out
  • 472 Answers
Check the lid switch most likely this is your problem.... they put the lid switch on there so when you raise the lid it shuts the motor down and stops machine...it is a safety device... if the unit is working on everything else you most likely have a bad lid switch...you can bypass to confirm prior to buying a new one.... good luck.... whirlpool models you have to remove 2 screws in console and flip consle over ...you will see a molex plug usually on right side under console with a 3 prong plug... take a jumper and jump out the side coming from the console normally 2 outside terminals. plug unit back in and see if it works....
Posted on Jan 03, 2011
How to diagnose hotpoint washer model hisr2120aoww only washing.not spinning and not draining?
my next step would be to check on sensors maybe it's stoping machine before its starting spin cycle water level drain hose plugged hope this helps
Feb 03, 2015 | Hotpoint Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Splendide 2000 will not spin water out
bad pump on bottom back or board see if voltage to pump motor
Jul 29, 2012 | Splendide RV Motorhome Laundry Appliance...
Washer will pause in mid-cycle and not turn back on
i wonder if it is full af water or empty often when the draib pump goes out it will shut down if it cannot drian in the alotted time if it is draining does it spin if you where to put it into a spin cycle if not door switch if it does spin and there is no water in it control is probable the next step recommend either sending more info or getting a professanial controls can get pricey
Jun 02, 2010 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 90 series doesn't spin out all the water
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Kenmore 22422 Top Load Washer
Water comes back in and stands after cycle is run
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
May 25, 2009 | Washing Machines
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 70 series washer
Hi juanmapr,
The next step after checking the power would be to put the washer into the spin cycle and see if the machine will spin. This will tell you two things. 1 It will tell you that no water is coming in at the start of the wash cycle. 2. It will tell you if the rest of the parts are functioning properly.
If the machine will not spin when in the spin cycle and you do not hear the motor turning then you may have a bad timer.
If the machine will spin but when you start a wash cycle the water will not fill then you will need a new water inlet valve.
Please send me the model number and any other questions you may have if this does not fixYa and I can ship you any parts you may need for your repair. Or just let me know if you need a step by step how to do any repair, I am glad to help. Please dont forget to rate me.
Mike Anderson (Owner)
Anderson Appliance Repair
(865)945-3808
Oct 27, 2008 | Kenmore 24032\24036 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
