My heater wont light. i can light it with a tourch, but it wont stay running
    President:
  • 2,468 Answers
The thermocouple that senses the flame is defective and won't keep the gas valve open to operate the unit,ace hardware carries most thermocouples,check them out,just get the right size that goes into the gas valve and make sure the sensing bulb is positioned within the flame for proper operation
Posted on Jan 03, 2011
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
My little buddy heater wont stay lit
If there is a draft it will blow out, if you run into it there is a safety shut off. If neither of those are the problem then I would check your regulator.
Feb 15, 2015 | Mr. Heater Heating & Cooling
My mr heater wont stay light unless its above 3. It only stays on about 5 min then pilot goes out. It is gas heater. What's wrong with my heater?
Theres a thermostat inside, if its too cold and not warming up the thermostat enough it will shut off because it thinks there is a problem.
Feb 07, 2013 | Heating & Cooling
The LCD (24 hour timer) is blank so the heater wont work
There is nothing you can do, turn on your oven if electric, or if gas open a window 4 inches and dont sleep with a gas burner running.
Oct 25, 2012 | Dimplex OFC2000TI Heater
My styhl 550 4-mix back pack leaf blower will not rev up,even after installing a new carb
Go to the exhaust muffler and use a socket to remove the muffler screen. If it is clogged, use a small propane tourch to burn the carbon inbedded in the screen. Once it turns to a greyish ash color. Lightly tap it to remove the ash. Reinstall it and then try again.
Mar 08, 2012 | Garden
Piolot light wont stay light.
Here's a solution that'll blow your socks off!
Get the thing running.
Then briskly tap the pilot supply line.
Watch as the line cleanses itself.
Should be fine for a long time.
Dec 14, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Heater core leak hoe do I fix
You will have to remove console, and all the venting and cover to heater core. Then go underneath the vehicle and disconnect both coolant hoses. Then remove heater core. You can go to autozone.com and register for full free online repair manual for your durango with everything you could need.
Dec 09, 2009 | 2000 Dodge Durango
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
