Question about Sony MHC-RXD3 CD Shelf System
Clicking when plugged in there is a loud clicking caused by these white things inside of the tape deck one. the white tabs move back and forth and do not stop till you unplug system.
  • Anonymous Aug 01, 2008
    I have the same problem.
    Problem Solver:
  • 5 Answers
Open the cassette holder and use a pen to push down on the carrier. So long as you don't try to use it again it should stop
Posted on Feb 05, 2009
  • 44 Answers
I have the same problem with my RXD3.
If you want that clicking sound to stop you can push down the heads in the casettdeck of the stereo. That makes the sound stops, but if you push down a casett/tape in the deck, the casett will catch up and probably get damaged because the clicking sound starts again and the tape will not get out of the deck. Though you have to unplug the system and then pull out the casett, but look out, the tape/casett can get hurt. //David
Posted on Jul 08, 2009
2 Suggested Answers
  • 40 Answers
SOURCE: loud clicking
Have you checked the rubber/elastic bands that turn the capstans in the cassette player. If they are loose they do not provide the proper tension and the player stops working properly.
Posted on Mar 07, 2009
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Why one tape at deck A won"t come out. it stock inside unit
There are lots of causes to this. For example the mechanism has jammed. The tape has become entangled in the capstan or elsewhere. Plastic damage causing the mechanism to not move back to the eject position. Some decks have a powered eject that is faulty. Broken spring, or one that has fell off.
May 28, 2014 | Pioneer CT-W205R Single Dual Cassette Deck
How do you hook up a sharp stereo cassette deck RT-W800
If that tape deck of yours has an audio line out jack (like the RCA red & white holes, usually located at the back), get an RCA plug to connect it to your stereo receiver's line in jack..... or
if that tape deck of yours doesn't have an audio line out jack but, instead, has phones (or headphones) jack (usually located at the side or front of the unit), then get a plug to connect it to your receiver's audio line in jack (RCA type, also coloured red & white).. Usually the plug is small so you may have to use an adapter for your tape deck's phones jack.
BOB (June 23rd '12 3:45am)
Apr 28, 2012 | Audio Players & Recorders
I am looking for a mode-switch for technics tape deck RS-M45
As a work-around, you could "protect" your tapes by removing the little snap-off tab in the top edge (left as viewing the side you want to play). That way the hardware can't possibly go into Record Mode and ruin a pre-recorded tape.
If you can see it, there is probably a little spring-loaded sensor arm inside the cassette well that 'feels' for the tab's presence. Is it free-moving and undamaged?
Nov 08, 2009 | Audio Players & Recorders
Going back and forth from recording to dubbing tapes
If there is a switch (either a mechanical switch or a relay) that changes the recording mode (something like normal/dub or record/dub), it might have oxydized contacts and this may be the cause of the problem. Cleaning the contacts inside the switch/relay or replacing the switch/relay will probably solve this.
You may want to check the switch prior to removing it. You can do it with a continuity tester (possibly with the kind that gives a sound signal when the continuity is good).
Otherwise, if the switch can be disassembled in a simple way, see if the contacts inside the switch are brownish/oxydized, if so, you need to clean them, but you also need to clean the clips that connect the contacts. Some fine sandpaper will do the trick, but be careful when you disassemble and reassemble the switch, some parts can easily get damaged.
regards
3rq8 (Triarcuate)
Nov 18, 2008 | Tascam 322 Advanced Dual Well Single...
Loud clicking
Open the cassette deck and use a pen to push down the heads. After this it probably works better to avoid using cassettes in this machine.
Feb 16, 2008 | Sony MHC-RXD3 CD Shelf System
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
Sony MHC-RXD3 CD Shelf System Logo
164 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
