Question about D-Link AirPlus DI-524 Wireless Router
Where can I find my DI-524 Username and Password?
  • 84 Answers
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Posted on Jan 03, 2011
  • 442 Answers
If you are trying to login to the router page and asking for a username and password try the following combinations,
Username: admin
Password: admin
Username: administrator
Password: password
Username: admin
Password: password
if this does not work, also check the usernanual, for referring to factory default username.
If that also does not work, you have to reset the router with the reset switch (this will reset all the settings to factory settings, you will loose the security settings also)
4 Suggested Answers
De Guyver
  • 123 Answers
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Posted on Feb 16, 2006
De Guyver
  • 123 Answers
g_aqua31
  • 47 Answers
SOURCE: DI-524 status led not blinking
Here are the instructions
  1. Make sure that you have a copy of the latest firmware and it has an *.exe file with it. Because the router's configuration page won't be available, you'll be needing the exe to some sort of force the firmware upgrade procedure.
  2. Unplug everything attached to your router except the power cable and LAN cable connected to your pc.
  3. Configure your TCP/IP with this info: IP:192.168.123.253, Default mask:255.255.255.0, Default Gateway:192.168.123.254 and DNS Server:192.168.123.254 (Use only 1 DNS server). Save this new configuration and reboot your pc.
  4. Unplug the power cable to your router as the pc reboots. When everything is up and running, plug the power cable. The status led will be flashing like crazy. It's normal.
  5. Use the exe file to upgrade your firmware. Make sure that the utility file (exe file) is able to recognize your router or else you won't be able to do a firmware upgrade. Now this may take a while, keep pressing the Refresh button to recognize your router. Once recognized you would see there 192.168.0.1 crash. Once you have this, you can now press the upgrade button.
  6. Wait for a while until the unit finishes the upgrade and once done, I think you have recovered the life of your router from the pits of hell. Hahahaha.
  7. You can now unplug the power of the router and restart your pc, see if everything is doing fine.
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
Posted on Nov 25, 2008
When i run wisard it ask about old passworld
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-774, and DI-784.
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The username is admin and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 4 To change the administrative password, enter a new password in the Admin section.
To change the user password, enter a new password in the User section.
Step 5 Click Apply then click Continue to save the settings.
Note: If you forget your password, you can reset the unit to factory defaults.
Click here for instructions.
Nov 02, 2010 | D-Link AirPlus DI-524 Wireless Router
What is the generic password
The default combination for the DI-524 is:
  • password: "admin"
  • username: (empty)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 17, 2010 | D-Link AirPlus DI-524 Wireless Router
How to set up security to the router DI 524,
To open the gui of the router open internet explorer and in the addres bar type 192.168.0.1 and hit enter. You would be prompted for a username and password. The default username as admin and password as <blank> for the unit.
Try this, in case you are not able to access the UI of the unit with the username and password try pressing the reset button on the unit for 20 seconds. This would restore factory defaults on the device, once done try to access the ui of the device as explained above
Jul 07, 2010 | D-Link AirPlus DI-524 Wireless Router
How do you reset the password for a D-link DI-524 Router
http://www.askmehelpdesk.com/wireless-technology/dlink-di524-up-router-password-username-removal-91794.html
Oct 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not open wizard
You can reset your router.
To reset your router, use the following steps (from http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/):
  1. Press the reset button [the tiny button on the back of your router, marked Reset] for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in Securing D-Link DI-524 Wireless Router to secure your router.
admin username: admin
Default admin username: admin Default admin password: <blank>
Aug 16, 2009 | D-Link (DWL-2200AP) 802.11g/b Wireless...
D-Link AirPlus DI-524 Wireless Router pass and username
Default IP: 192.168.0.1
Default username: admin
Default password: *blank*
Jan 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Need to find DI-524 in system
Type 192.168.0.1 into your internet browser URL box.
It'll ask you for Username and Password. The default will be 'admin' fro username and 'password' for password. this will let you see all the settings for your router. don't mess about in here too much, there be dragons! But you can change the username and/or the password in there.
hope this helps
chris
Dec 17, 2008 | D-Link AirPlus DI-524 Wireless Router
Dont know the password and user name
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Logging onto the DI-524 Router
hello..
The default username for the DI-524 is admin and the password is blank.
Jul 02, 2008 | D-Link AirPlus DI-524 Wireless Router
Forgot the URL for my DLink 525 Wireless router
Hi, To enter the webinterface configuration of your D-Link 524, type "192.168.0.1" at the address bar of any browser. UserName is "admin" and password - leave blank. Good luck and kind regards.
Oct 10, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
1,038 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
