Question about Nikon COOLPIX P5100 Digital Camera
I droped my nikon L110 in the saltwater in the beach... I didnt nessicarly "drop it" i was walking back to shore and i triped and some of the water from the splash got into the lens i belive... the lens is sticking out and wont turn on or the lens wont get back in... PLEASEE help me... i just got this camera for the holidays.. thank you. -jenna
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 03, 2011
Nikon L110 battery getting discharge in few clicks
It could be a bad battery charger circuit in your camera. Try charging your batteries in an external charger. Adorama.com sells an Delcon Devices external battery charger for $9.95. If that works, your problem is solved. If not, you will need to send the camera to Nikon USA for repair.
Jul 11, 2013 | Nikon Coolpix L110 Digital Camera
PC cannot recognise usb for nikon l110
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
May 07, 2012 | Nikon Coolpix L110 Digital Camera
My Nikon coolpix L110 is not responding at all or takes forever to respond
Try resetting the camera by removing the battery for 15 mins, then insert the battery and go into the Menu to set the Date and Time.
Mar 20, 2012 | Nikon Coolpix L110 Digital Camera
I think i need a new LCD screen for my Nikon Coolpix L110. The glass cover on the outside is perfectly fine, it is something underneath that is cracked. How much will something like this cost?
The installation of a new LCD and return shipping of the camera is about $75. Here's a link for you:
http://www.darntoothysam.com/products/Nikon-Coolpix-L110-Camera-LCD-Screen-Repair-Service.html
Hope this helps!
Thomas Drayton
Owner www.darntoothysam.com
Affordable Digital Camera Repair
Aug 03, 2011 | Nikon Coolpix L110 Digital Camera
Im knew at this and i want to know how to take say like a picture of a flower and zoom in so it focuses on one part of it, and blurry in the back ground how do i do that with the nikon coolpix L110?
That's called depth of field and what you're looking for is a shallow depth of field. This is achieved by using a wide aperture (an F stop of 5.6 or lower). I'm not too familiar with the L110 but you may achieve this with the Scene Mode "close up" which is available on your camera.
Jan 21, 2011 | Nikon Coolpix L110 Digital Camera
How do i take professional pictures with the nikon coolpix l110? do i need to photoshop them or something? i dont know how to do that. i see many photos on youtube and photobucket from the nikon coolpix...
The difference between a professional and an amateur is not the camera. A pro gets paid for his pictures, an amateur does not.
Go to your local library and browse through some introductory photography books. They will explain how to do things like shoot with a narrow depth of field (blurred backgrounds).
Dec 23, 2010 | Nikon Coolpix L110 Digital Camera
How to get nikon coolpix L110 driver for win7?
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery, Picasa, or Nikon Transfer.
Nov 27, 2010 | Nikon Coolpix L110 Digital Camera
Nikon COOLPIX P5100 Digital Camera Logo
125 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
