Question about Logitech MX 5500 Revolution Keyboard
Can't install time and date on new keyboard - Logitech MX 5500 Revolution Keyboard
How do i set the clock? l have clicked on clock and tried entering numbers but nothing happens
Enter into BIOS
  • Enter the CMOS setup.
  • system setup screen see the date and time
  • Using your arow key on the keyboard navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow key / your page up / page down keys to change the date.
Using Msdos command
  • Press Control + r key togather
  • type cmd
  • on the black screen type date
  • press enter. It will be showing the current date and also asking you to put the new date in the format mm-dd-yy,
  • type new one as per format
  • press enter
For time
type cmd
on the black screen type time
press enter. It will be asking for new time,enter new time and close the black box.
GOOD LUCK!!
Sep 24, 2010 | Computers & Internet
How to set date & time MX3200 keyboard from Logiitech
use your mouse curser; place over "time" in lower right corner of screen in bottom taskbar; right click;should have adjust date/time; left click;adjust date/time
Mar 08, 2010 | Logitech Cordless Desktop MX3200 Laser...
How do I adjust the clock on my mx5500?
The MX 5000 and diNovo Media Laser utilize the Adjust Time/Date function on your PC's clock to set the keyboard's LCD display. In order for the PC's clock to synchronize with the LCD display, the SetPoint for Bluetooth software is required to be installed and enabled. Once you have installed SetPoint for Bluetooth, the LCD display will automatically sync with the system's clock.
Solution
If your LCD is not displaying the date and time and SetPoint for Bluetooth is not installed:
  1. Download the latest version of SetPoint for your device from the Logitech Downloads page.
  2. Install SetPoint on your system. (For additional information regarding installing SetPoint for Bluetooth, please refer to Knowledge Base article 5890 ).
Dec 03, 2009 | Logitech MX5500 Keyboard/Mouse
How can I set the correct date and time on my Logitech MX 3200 wireless keyboard?
"To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Nov 10, 2009 | Logitech Wireless Access Duo Optical...
How do I change the date and time
there are two areas where you need to change the date and time.
1. Bios. To get into your bios you will need to press the DEL key at computer startup then arrow down to the time and date.
2. Once you are in windows down in the bottom right corner of the screen double click on the time and a new window will appear you can then adjust your date and time.
Nov 04, 2009 | Logitech MX 5500 Revolution Keyboard
Time and date wrong on keyboard
To enter the date and time setting format,press the FN key and the F10 key at the same time.
Hope it works for you.
Mar 21, 2009 | Logitech Cordless Desktop MX3200...
I have a mx3200 cordless keyboard that has a clock and date window. The alarm clock goes off at 2:00pm how do i turn it off? Do you have a manual I can download?
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date: "To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
Setting the date and time on the keyboard
Hi Wlingrell,
Thanks for your posting in FIXYA.
Go To Control Panel --> Open --> Date and Time --> Click on Change Date and Time,, set the exact date and time.. Next time you will get the correct time and date on your PC.
Please use this link to obtain the manual if your Keyboard is of Logitech:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=8040&p_created=1204577470&p_sid=8gAUtIdj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD02NCw2NCZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Db3JkbGVzcyBEZXNrdG9wwq4gTVjihKIgMzIwMCBMYXNlcg**&p_li=&p_topview=1
Best of luck
Ellin
Sep 11, 2008 | Logitech Computers & Internet
Logitech MX 5500 Revolution Keyboard Logo
21 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
