Question about HP LaserJet P2015dn Printer
Metwork card i am trying to install a hp laserjet p2015 dn printer in my office and it is not connecting- do i need a network card if so where is it in my printer
  • Anonymous Sep 25, 2008
    The printer does not connect...as in the system does not detect it. I dont know if its the printer port or maybe its my computer. But the printer usb cable works as i tested with my scanner. Pls help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Your printer is a dn model, which means it is duplex + network. Please unplug the network cable and perform the following:
Cold reset A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings. Use the following procedure to perform a cold reset.
  1. Turn off the printer.
  2. Press and hold the Go button.
  3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
  4. Release the Go button.
    If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Network reset A network reset changes all network system parameters in NVRAM to the factory defaults. During the network-reset process, all button presses are ignored.
Use the following procedure to perform a network reset.
  2. Simultaneously Press and hold the Go and Job Cancel buttons.
  3. Turn on the printer and continue to hold the Go and Job Cancel buttons for approximately 10 seconds, but no longer than 20 seconds. During this process, the Attention light turns on.
  4. Release the Go and Job Cancel buttons. The Attention , Ready , and Go lights begin cycling from front to back. After the network-reset process is complete, the device returns to the ready state.
    If the Attention and Ready lights illuminate before you release the Job Cancel button, start again at step 1.
Now connect the netowrk cable and wait for 5-mins. After that print a configuration page and confirm the IP address.
- Nikhil
Posted on Nov 07, 2008
Hello , I need to know if hp-laserjet p2015 printer have a "built in" network card ? if not how can i share it between two computer by using a switch ?
HP Laser jet P2015n & P2015dn models having network facility, there is no option to add on network card for this series.
1. Install the printer locally through USB in one system and share it to others if its non "N" printer.
2. You can connect use network to USB convertor to print thorugh network. pl see the link for one of the sample product..
http://uk.shopping.com/Conrad-USB-2-0-NETWORK-ADAPTER/info
Sep 20, 2011 | HP LaserJet P2015 Printer
I am trying to connect to the network printer (hp laserjet p2015) I was not able to print so I uninstalled the printer and tried to add it again, but couldnt. windows stated that the driver was not...
Hi
Within the HP tool box, there is a utility called "scrubber" Run this, it will seem like nothing happened, , re install the printe rsoftware from the CD or disc, and when requested, plug in your printer. Dont plug the printer in first.
Dec 21, 2010 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
I do not have the cd for installation of printer in my pc
You can get the drivers for the HP LaserJet P2015 from HERE.
Just select the Operating System from the list and download it.
All The Best.
With Regards:-
Subhankar Ghosh
Nov 17, 2010 | HP LaserJet P2015 Printer
I have a printer hp laser jet p2015 and laptop with vista the windows can not recognized the device what i can doo
From the manufacturer's web-site: http://support.hp.com
enter 'P2015' and do a search.
Select your model of printer.
Select Windows Vista.
Select the device-driver, download it, and install it.
Sep 28, 2010 | HP LaserJet P2015 Printer
Install HP LaserJet P2015 Printer
Click Here for your hp p2015 driver, input your operating system and it'll give you the appropriate driver for that system. hope this helps and if so please mark a FixYa!!
Aug 24, 2010 | HP LaserJet P2015 Printer
in printer properties disable the power saving mode.
Jan 28, 2010 | HP LaserJet P2015 Printer
How to connect to network printer hp laserjet 2015 PCL5
I cannot connect to hp laserjet 2015 PCL5. wia network...
im using 64 bit windows 7, and tell me that Windows cant find a driver for HP.........i install driver and nothing........
Jan 18, 2010 | HP LaserJet P2015 Printer
Install hp laser jet p2015
Please find below the link to download the driver.
I hope that the printer is connected via USB. If yes, please do not connect the USB cable before running the software. The software shall prompt you to connect the printer. Once prompted, please connect the USB cable and make sure the printer is powered on.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=LJ+P2015
- Nikhil
Nov 04, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
444 people viewed this question
Ben Johnson
