Question about Compaq Evo N610C Notebook
Error fixed parameter table or BIOS error systen
4 Suggested Answers
SOURCE: '03 compaq presario x1000
On a desktop pc u hear continuos beeping it's something to do with da ram so try replacing the ram or reseat the ram for help go to compaq.com
Posted on May 10, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: it clicks alot when it's booting and i can't get i...
It seems as if your hard drive has failed or is going to fail. When you hear a clicking noise like that with no CD in the system that is usually what the cause is.
Posted on May 24, 2010
Davethesnake
  • 689 Answers
SOURCE: Turn on notebook compaq nx6120,
You should have gone into your Bios pages first.Press F2 whilst booting,learn how to to configure these pages,use the "tab" button to navigate and arrow keys ,Save and exit or restore to factory defaults,learn how to use these pages to enable correct boot sequence--good luck!
Davey Snake!
Posted on Oct 23, 2010
Tengo un problema q es fixed disk parameter table or BIOS error system halted que puedo hacer
Deberías tener ciertas habilidades técnicas para resolver este problema, no es sencillo lo mejor sera que lleves tu computadora con un especialista el error que te marca es un error de la memoria del BIOS la encargada de iniciar tu sistema operativo(windows) llévala al técnico.
Suerte.
Aug 25, 2011 | Compaq Armada M700 Motherboard
Fixed Disk Parameter Table or BIOS Error Okay, so I was browsing around the web the other day. My notebook completely locked up, and I had to hold in the power button for 10 seconds to do a hard shut down....
Remove the hard drive and see if you get the same symptom. It should boot, then go into the BIOS and see if it recognizes the RAMs. Re-seat the RAMs if it doesn't boot - if you have two circuit boards - try one at a time. The motherboard can also be your problem.
Jan 21, 2011 | HP Compaq Smartbuy 5102 166 GHz Intel Atom...
Turn on notebook compaq nx6120, always 3 beeps and message "Fixed Disk Parameter Table or BIOS Error" and the low line is "System Halted", And another, i remove the HDD from my notebook in order to...
Davey Snake!
Oct 23, 2010 | HP Compaq nx6110 PC Laptop
It clicks alot when it's booting and i can't get it to turn all the way on. It says fixed disc parameter table or bios error system halted
May 20, 2010 | Compaq Armada M700 Notebook
Problem: KERNEL_DATA_INPAGE_ERROR Technical information: ***STOP: 0x0000007A (0xC0403638, 0xC0000056, 0x4277F860, 0x806C7913) ***acpi.sys ? Address 806C7913 base at 80692000, DateStamp 49c01a37
The KERNEL_DATA_INPAGE_ERROR bug check has a value of 0x0000007A. This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
Parameters The four parameters that are listed in the message can have three possible meanings. If the first parameter is 1 or 2, or 3 and the third parameter is 0, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (1, 2, or 3) 2 The error status (usually an I/O status code) 3 If Lock Type is 1: the current process
If Lock Type is 2 or 3: 0
4 The virtual address that could not be paged into memory
If the first parameter is 3 (and the third parameter is nonzero) or 4, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (3 or 4) 2 The error status (typically an I/O status code) 3 The address of the InPageSupport structure 4 The faulting address
Otherwise, the parameters have the following definitions.
Parameter Description 1 The address of the page table entry (PTE) 2 The error status (usually an I/O status code) 3 The PTE contents 4 The faulting address
Cause Frequently, you can determine the cause of the KERNEL_DATA_INPAGE_ERROR bug check from the error status (Parameter 2). Some common status codes include the following:
  • 0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
  • 0xC000009C, or STATUS_DEVICE_DATA_ERROR, typically indicates bad blocks (sectors) on the hard disk.
  • 0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose cabling, termination, or that the controller does not see the hard disk.
  • 0xC000016A, or STATUS_DISK_OPERATION_FAILED, indicates bad blocks (sectors) on the hard disk.
  • 0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper termination or defective cabling on SCSI devices or that two devices are trying to use the same IRQ.
These status codes are the most common ones that have specific causes. For more information about other possible status codes that can be returned, see the Ntstatus.h file in the Microsoft Windows Driver Kit (WDK).
Another common cause of this error message is defective hardware or failing RAM.
A virus infection can also cause this bug check.
Resolving the Problem Resolving a bad block problem: An I/O status code of 0xC000009C or 0xC000016A typically indicates that the data could not be read from the disk because of a bad block (sector). If you can restart the computer after the error, Autochk runs automatically and attempts to map the bad sector to prevent it from being used anymore.
If Autochk does not scan the hard disk for errors, you can manually start the disk scanner. Run Chkdsk /f /r on the system partition. You must restart the computer before the disk scan begins. If you cannot start the computer because of the error, use the Recovery Console and run Chkdsk /r.
Warning If your system partition is formatted with the FAT file system, the long file names that the Windows operating system uses might be damaged if you use Scandisk or another MS-DOS-based hard disk tool to verify the integrity of your hard disk from MS-DOS. Always use the version of Chkdsk that matches your version of Windows.
Resolving a defective hardware problem: If the I/O status is C0000185 and the paging file is on an SCSI disk, check the disk cabling and SCSI termination for problems.
Resolving a failing RAM problem: Run the hardware diagnostics that the system manufacturer supplies, especially the memory scanner. For more information about these procedures, see the owner's manual for your computer.
Check that all the adapter cards in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure adapter card contacts are clean.
Check the System Log in Event Viewer for additional error messages that might help identify the device that is causing the error. You can also disable memory caching of the BIOS to try to resolve this error.
Make sure that the latest Windows Service Pack is installed.
If the preceding steps do not resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can cause this error.
Resolving a virus infection: Check your computer for viruses by using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. All Windows file systems can be infected by viruses.
Jul 12, 2009 | Microsoft Windows Vista Home Premium with...
Bios Issue/Hard Drive Upgrade
i have installed a 60gb hdd into an m700 without even having to stuff with the bios...
Xp sp2 allows you to install larger drives then the bios reccomends.
Feb 18, 2009 | Compaq Armada M700 Notebook
Nov 11, 2008 | Compaq Presario X1000 Notebook
Bios Settings
I had similar problem few years ago.
On the hard drive manufacturer site you should find utility which will "cheat" your laptop bios and control the hard drive bypassing the bios.
Nov 07, 2008 | Compaq Armada M700 Notebook
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
Compaq Evo N610C Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
